RA 2009 Tool kit list
I'm starting this thread for anyone who wants to know what tools they need for whatever work they need to do on there cars. We should be listing all the tools that are needed to do all the How tos in the section. It think it would be most useful in the following format:
Install EVO X FMIC XXX = tools XXXX XXXXXXX XXXXXXXXXX Hope I started something useful. |
realistically, there are very few tools needed at all to work on most bolt-on diy-type modifications for any mitsubishi...
1/4, 3/8, and 1/2" ratchets, extensions, and swivels 10, 12, 14, 17, 19, 21, 24, 26 and 32mm -sockets -wrenches those are just about the only sizes you will ever encounter on the car when it comes to nuts and bolts, so basically having a set of those wrenches and sockets in 1/4" and 3/8" sockets with ratchets (1/2" drive for the 17 and up makes it easier for sure) along with some ratchet extensions and universal swivel joints is about all you would need for this car. only other things that are quite commonly needed: philips and flat head screw drivers in various sizes and lengths interior trim panel remover tool rubber mallet/deadblow hammer prybar assortment wire cutters/strippers/crimpers metric allen (hex) bit set, up to 10mm more specialty type stuff needed for the heavier-duty type jobs, but the basics can pretty much all be accomplished with what i've got listed here. good luck {thumbup} |
Originally Posted by 03chi-town0Z
(Post 7613278)
1/4, 3/8, and 1/2" ratchets, extensions, and swivels 10, 12, 14, 17, and 21mm -sockets -wrenches those are just about the only sizes you will ever encounter on the car when it comes to nuts and bolts, so basically having a set of those wrenches and sockets in 1/4" and 3/8" sockets with ratchets (1/2" drive for the 17 and 21 makes it easier for sure) along with some ratchet extensions and universal swivel joints is about all you would need for this car. only other things that are quite commonly needed: philips and flat head screw drivers in various sizes and lengths interior trim panel remover tool rubber mallet/deadblow hammer prybar assortment wire cutters/strippers/crimpers more specialty type stuff needed for the heavier-duty type jobs, but the basics can pretty much all be accomplished with what i've got listed here. good luck {thumbup} Thanks very much. |
very helpful
omg this is the best thread ever now i know how to work on my car and change my engine:lol:
24mm wrench for rear diff fill plug and 10mm allen wrench for drain plug.
24mm wrench for transfer case drain plug and IIRC, 17mm wrench for transfer case fill plug. |
Thanks this will help me alot
Originally Posted by 20si06
(Post 7617511)
very helpful
