Replace fog light glass for $16
broken glass? :mad:
https://cimg7.ibsrv.net/gimg/www.evo...27b6585656.jpg You can replace them with generic 3.5" glass from ebay fog light kits for various vehicles. Ford Focus, Subaru legacy, Mitsubishi RVR, etc Usually you can find a set for $31 shipped which comes out to $15.50 a glass! {thumbup} Thing you'll need: Philips screwdriver eBay fog light kit of your choice Permatex ultra black Glass bowl or plastic container gasoline glass cleaner Plastic razor blade or scraping tool that will not scratch glass Step 1: Take the glass or plastic container ( i used an old Frisbee) and fill with gasoline to about 1" deep Submerge your ebay fog glass facing down, into the gasoline. make sure the gasoline is slighlty higher than the glass edge. let it soak for 24r. http://i238.photobucket.com/albums/f...psanip48dt.jpg If the glass does not come out of the housing after 24hr, pour some gasoline into the fog housing slightly past the glass edge and let it soak for another 24hr. Step 2: Separate the glass from the ebay housing. The glass should almost fall off or pop out with just your hands prying it off. If it does not come out, you most likely did not have the light submerged enough to reach and loosen the black sealant from the body. https://cimg7.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 3: Clean off the old sealant from the glass. I used a plastic razor blade from a local hardware store. https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 4: Take out the old broken glass from the OEM housing. I used a screw driver through the bulb opening on the back to push the glass outward and then used pliers to take out the broken chucks of glass. https://cimg9.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 5: Clean out the old gasket material from the OEM housing. I used a plastic pry tool to get most of it out. then test fit the oem housing to the new glass. https://cimg6.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 6: Clean both the glass and the housing with glass cleaner. https://cimg4.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 7: Apply Permatex Ultra Black to the OEM housing around the edge filling the gap where the glass will sit. https://cimg3.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg4.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 8: Place the glass on the housing and press down so that it sits flush with the housing. Let it fully dry for 24hr. https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.jpg Step 9: Install fog light bulbs and mount back onto the car! :beer: https://cimg2.ibsrv.net/gimg/www.evo...27b6585656.jpg |
Glass source
http://www.ebay.com/itm/Ford-Focus-Explorer-Mustang-Ranger-Clear-Fog-Lights-Pair-RH-LH-Right-Left-/231496816644?fits=Make%3AFord%7CModel%3AFocus&rmvSB=true |
Mine got cracked just before I deployed to Afghanistan. I will take care of it when I get home in July. Thanks for the information on this. I was just going to go to the dealer and buy a new light.
Great post, this is on my to do list this spring now, thanks dude!!
FYI, if you throw the fog lights in the oven at 350 degrees for about 12 minutes, you can use a knife to separate the glass from the fog light without having to wait. I used black DAP gasket maker from the local hardware store, it worked great!
I initially tried them in the oven but had no luck, maybe i didn't leave them in long enoght. I'm glad you found the how to usefull.
Great post!
