Swagger Wagon Build Thread
I figured I would start my own build thread since I'm planning to go a different direction than others with build threads. If your looking for a thread to help you build the fastest Ralliart on the strip, track or Auto-X this isn't it. There will be performance parts discussed as I'm a firm believer in Function over Form (but more Function first, Form second), however I don't have any issues doing things that are all form as long as they don't have a negative function.
Ill start by recapping what Ive already done. Tein Springs Blacked out front ring and window trim K&N drop in filter Various versions of the GTS Basemap - Currently running V2 93 Oct Stock Pill On to the new stuff and the future Rota Grid - 18x8.5 +44 from www.wheeldude.com I have to say these guys are good people and have great customer service. I sent emails back and forth to Tommy for close to a month before buying the wheels. Once I got them the center caps didn't fit because of the hub, but Tommy was quick to fix the problem and send me a new set that fit perfectly. Id recommend them to anyone looking for a set of wheels. http://farm5.static.flickr.com/4091/...8aee501f_z.jpg http://farm5.static.flickr.com/4084/...0f2d75d6_z.jpg TWM Abrams RL Shift Knob More info can be found here https://www.evolutionm.net/forums/09...hift-knob.html http://farm5.static.flickr.com/4145/...fb68f721_z.jpg EBC Slotted and Dimpled Rotors, EBC Red Stuff Pads, AMS Braided Brake Lines This (minus the lines) actually ended up being a huge pain to order and get, installation only had one small hiccup. I originally ordered these off a website that had the lowest price. When I ordered them I was expecting to get gold rotors based off the EBC website. However when they arrived they were black. After some back and forth with the website and EBC is was determined that the rotors and pads that were sent to me were incorrect. After a couple weeks the correct parts were sent to me, unfortunately they were still black. Not a huge deal but I really wanted gold to match the wheels. The rotors and pads went on fine, however the front lines were tough. For some reason there is a large amount of rust already built up on the car and I only have 6k miles. The lines had rust on the connections as well as up into the threads which made it very difficult to get off even using a line wrench. However, once they were off the AMS lines went on without much issue. Fronts http://farm5.static.flickr.com/4153/...0bc7b449_z.jpg With the wheel http://farm5.static.flickr.com/4146/...8ee7ba8e_z.jpg Rear http://farm5.static.flickr.com/4149/...bf41be3f_z.jpg In case you didn't notice the dimples and slots are different between the rotors. The fronts are all black, the rears have been machined after being anodized. Ill be inquiring to EBC about this. However, after about 5 miles the black has already been worn away from where the pads sit. What is nice though is that everything else on the rotor is still black so it sets the rims off a bit better. Part numbers Front rotors.. GD7336 Rear rotors.. GD1576 Front pads.. DP3954C - from an Eagle Talon Rear pads.. DP31407C - from a Montero (according to the boxes) Ultimate Racing TBE Currently I only have the Cat Back section on. I don't have my wideband yet and I want to be able to continue to run the GTS Basemap so I kept the DP and Cat section off for now. When I heard people talk about how loud the exhaust is I figured most of them were just being too sensitive, however it is a loud exhaust. My old GTI had catless downpipe to full 3" with just a Magnaflow muffler and it wasn't this loud. However, I'm not sure I don't like it. Ive only had about 20 min of driving with it on so I'm going to reserve judgment, also until i put the DP and midpipe on. I don't have pics of it yet as it was close to dark when we got finished installing it. License Plate Frame I have all the parts to build Version 2.0 of the plate frame I had on my GTI http://i266.photobucket.com/albums/i...ati/MyFast.jpg Frame is done! http://farm5.static.flickr.com/4147/...910dcd47_z.jpg Parts left to install G2 Caliper paint Trying to decide between blue and black, have both sitting in my room AMI A Pillar pod Waiting for it to arrive, should be here in the next couple weeks. Will be installing analog boost gauge and wideband. Edit 10/2/10 http://farm5.static.flickr.com/4091/...cc3ab6b7_z.jpg My sweet new custom gauge pod :D Actually its just a temporary pod until my AMI pillar comes in. Both gauges are AEM analog gauges (Boost and AFR). I like that both gauges are electrical and we didn't have to run a vacuum tube from the T to the gauge. I used the serial cable and serial to USB adapter from Mellon tunning to be able to data log the AFR gauge. The USB connection is run to behind the panel to the left of the steering wheel. Rally Armor UR Mud Flaps Got these installed these today, it was dark after I was done so no pictures yet. Ill have them up soon, but it makes the car look different. A/B/C Pillar customization Expanding on a project I started on with my GTI Parcel Shelf customization A reworking of a mod Ive seen in the JDM crowd Super Secret Project 1 In the idea phase right now. Ill add more info as it progresses. This project is a go and Ill be updating the thread more with progress as it happens. However, I wont be actually saying what it is until its closer to being done. Step 1: Order Material Step 2: Order mounting solution - DONE Step 3: Construction Step 4: Accesories Step 5: Paint/Powder Super Secret Project 2 In the idea phase right now. Ill add more info as it progresses. |
Car looks great. :)
I like the spikes! Just be careful in the front while walking around the car. :P - Bryan |
The car looks great man. If you don't mind me asking. Where did you get the EBC rotors from?
Originally Posted by GST Motorsports
(Post 8646871)
Car looks great. :)
Originally Posted by boondoc
(Post 8646891)
Thanx. One more question, GD7379(front) & GD7381(rear) Are these the part numbers?
Nevermind i got it. |
Love the title
(Post 8646921)
Nevermind i got it. Front rotors.. GD7336 Rear rotors.. GD1576 Front pads.. DP3954C Rear pads.. DP31407C These are the part numbers that I was given by Chris at EBC. Front pads are from a Talon, and the rears are from a Montero, according to the stickers on the box.
Originally Posted by EvoIX2240
(Post 8646921)
Love the title
good to see another sportback :) very nice indeed
Originally Posted by DaJackson
(Post 8647290)
Rear rotors.. GD1576 Front pads.. DP3954C Rear pads.. DP31407C These are the part numbers that I was given by Chris at EBC. Front pads are from a Talon, and the rears are from a Montero, according to the stickers on the box. |
Great lookin S.B. man
That shift knob is pretty sweet!
looks hot, i'd go with the black calipers... i just painted my calipers and oem rotor hubs black looks pretty nice on my RG sport back
car looks great, a few questions
why the "dimple" rotors and also why color rotors. is the paint high temp? im guessin its just for looks. and do braided brake lines add that much of a diff? |
License plate frame is done, unfortunately it will be a few days before I can get pics.
Originally Posted by robyn402
(Post 8649244)
Originally Posted by eyekyu
(Post 8649341)
why the "dimple" rotors and also why color rotors. is the paint high temp? im guessin its just for looks. and do braided brake lines add that much of a diff? The black anodizing helps to prevent rust on non braking surfaces. It also looks better in my opinion. Its not paint, its anodized. Braided lines do not expand under heavy breaking like the stock rubber lines do. It helps in pedal feel too. Braided lines made a huge difference in my GTI, but on the Ralliart is wasn't as profound, however still an improvement. |
im liking the wagon, looks great with the blue n gold...
