EVO X MR BBS wheels on RA'10
hey guys just wanna share how the BBS wheels fits the RA (UPDATED)
Wheel Size: 18x8.5 +38 offset, Center Bore 67.1 Tire Size: 245/40R18 Yokohama Advan A13C (MY2008) Comments: Forged, wheels are 18.5 lbs; wheel + tire ~43 lbs. the good: *BBS is so much lighter than the OEM wheels *steering feels light as well *excellent handling *looks so much better the the stock wheels *NO RUBBING issues with swift spring the bad: *increase ride height because of the fatter tires even with swift springs *front wheels stick out *slightly affects gas mileage because of the wider tires http://img602.imageshack.us/img602/8609/photo6u.jpg http://img684.imageshack.us/img684/8545/photo75j.jpg http://img148.imageshack.us/img148/3650/photo72h.jpg Uploaded with ImageShack.us http://img25.imageshack.us/img25/4526/photo73m.jpg Uploaded with ImageShack.us http://img3.imageshack.us/img3/8946/photo71vw.jpg Uploaded with ImageShack.us front wheels http://img199.imageshack.us/img199/1346/photohk.jpg Uploaded with ImageShack.us http://img210.imageshack.us/img210/9051/photo70f.jpg Uploaded with ImageShack.us http://img826.imageshack.us/img826/4004/photo74.jpg Uploaded with ImageShack.us |
Beautiful
Originally Posted by chazyronnie
(Post 8979550)
the good: *BBS is so much lighter the OEM wheels *steering feels light as well *excellent handling *looks so much better the the stock wheels *NO RUBBING issues with swift spring the bad: *increase ride height because of the fatter tires 245/60 *front wheels stick out *affects gas mileage because of the wider tires -The ride height stayed the same for me -The front wheels don't really stick out for me but then again, I am on RRM springs -Gas mileage actually stayed the same and improved a little as well. I would say this is because the wheels are lighter. BEAUTIFUL nonetheless! |
Looks good bro. You know these wheels bumped your whp a little.
the ride height should be the same if not little less.. the tires on the BBS are 245/40 not 60 profile.. which is only 0.1" smaller than stock 215/45 so nothing in it really.. other than that looks good :) minus the cf band aid you have on :D
Originally Posted by bye2u
(Post 8979649)
the ride height should be the same if not little less.. The tires on the bbs are 245/40 not 60 profile.. Which is only 0.1" smaller than stock 215/45 so nothing in it really.. Other than that looks good :) minus the cf band aid you have on :d
You should powder-coat them :D
Where can i get me some!!!
Originally Posted by Jdunn502
(Post 8979888)
+1^^ dont forget your tools and jack stands :D
(Post 8979888)
Looks good~
Looks great, I am a strong supporter of buying another vehicles stock wheels to keep , or until you can afford quality ones instead of buying cheap brands. :thumbup:
i wanna know about the fenders. Are those the actual vents off an X ? If so did you cut to make them fit?
Wheels look good though. |
I thought we would rub being lowered on those wheels with 245s and fenders that aren't rolled?
| All times are GMT -7. The time now is 03:59 PM. |
