wideband sensor placement on QTP downpipe
Old Jul 15, 2008 | 09:43 AM
slvevo8's Avatar
Should the sensor be installed before the split, or at the end, right where it bolts up to the cat?
Old Jul 15, 2008 | 10:56 AM
justboosted02's Avatar
before the split, you want the sensor to see ALL the gases
Old Jul 16, 2008 | 08:30 AM
slvevo8's Avatar
Opening the cutout will cause me to run rich, correct?
Old Jul 16, 2008 | 09:26 AM
the cut out wont directly make you run rich, however when you open the cutout you might hit higher loads which are tuned richer...
in any case you should get a retune
Old Apr 23, 2012 | 09:09 PM
10isace's Avatar
I'm bumping an old thread I know, but I just had to laugh at these 2 J.A.'s that screwed up my DP.
I bought a QTP DP from a member on here with an O2 bung attached. Ever since I put on the QTP DP with a SP boost cutout, I would get really rich at WOT at 4K rpm to redline. The cutout would kick open at about 10psi around 3K rpm. I tried tuning it out, but I couldn't get it lean enough.
Then I had an epiphany. The freaking sensor is after the split, so when the cutout opens up, the sensor is reading probably less than 25% of the exhaust gases. I'm sure I'm really lean at WOT! So I'm laughing at the JA who sold it to me and to the other JA who didn't catch this, me. Luckily, nothing bad has happened. I have been getting some knock at high rpm's, but I'm trying to stay out of boost until I can get a new bung before the split.
Old Apr 23, 2012 | 09:18 PM
10isace's Avatar
I just looked at my fuel maps and I'm about 0.6 leaner now trying to get the AFR's right. I think I'll put in my rich tune from before the cutout to be safe.
raidokoiv
Aug 24, 2019 12:07 PM
Fabillionaire
Apr 10, 2013 09:09 AM
Mitchubishievo
For Sale - Wheels / Tires
Jan 12, 2013 06:47 PM
dhe_answer
13
Oct 9, 2012 07:59 AM
Onkar02
Lancer Engine Management / Tuning Forums
Oct 17, 2008 11:11 AM
