Evo X Drag Times list
Old Jun 24, 2013 | 06:52 PM
  #61
KozmicMotorSpts's Avatar
Originally Posted by Darksun280
List updated. Let me know what mod list you want me to add. Good pass guys.
Kozmic Stg5 longblock 2.2L Stroker, ETS 6466 Turbo Kit, E85 Fuel, Stock ECU Kozmic27 Tuned, Kozmic Built Trans with "Magic Pack" Clutches.
Old Jun 26, 2013 | 10:02 PM
  #62
Hiboost's Avatar
Lightbulb No more stock turbo - now testing the 20G!
Sick MPH for sure, but the short time makes me cry! With my short time of 1.715 that could have been been a mid 10 second run!
Honestly I think there should be more Evo X MR's in the 11's, especially if you keep your turbo setup on the responsive side relative to engine displacement to counter the fixed 5000 RPM stationary limiter that builds ZERO boost.
I have some updates on my own 2011 Evo X MR: I'm still running stock clutch packs here but I have my boost curve tapering in the torque hit from 3000-4000 rpm's and trying my best to keep those clutch packs from seeing any slip in Super Sport mode.
Last fall on a cool high pressure boost night I ran the stock turbo to 11.965 @ 113.82 which has pretty good but the stocker was tapping out on the top end with the boost taper. There may have been a bit more in it with the cams but I got too impatient. After doing some maintenance in my engine bay I decided to try the 20G compressor wheel and housing swap for a low buck power upgrade to get me closer to the class limits in NARRA Time Trials TT3 class.
According to before and after Virtual Dyno comparisons there is a good 30-40 whp bump with the 20G compressor wheel upgrade thanks to it allowing an extra 3-4 psi on the top end. Spool is still reasonable as well since it hits 20 psi in 4th by 2900 versus 2800 using the stock turbo. If you don't mind the labor I feel the 20G compressor upgrade is a really good value for the gains. With the stock turbo off the car for any reason it's a no brainer to spend around $200 on this 20G Upgrade. If you have to pay someone to install the turbo or dread tearing into it yourself I would suggest moving to an FP Green or larger to make the pain worth the effort though.
I made these drag passes on a hot and humid night where there was a low pressure front moving in so compared to a couple nights earlier where the car felt crazy fast it makes sense that most people were down one or two tenths and mph. My car is by no means setup for drag racing but I adjusted my Aeromotions wing to zero angle of attack and still I managed a 1.715 short time after dropping my air pressures in the Hankook R-S3 tires to 30 psi instead of my regular 36 psi cold.
60': 1.715
1/8: 7.548 @ 90.51
1/4: 11.758 @ 116.24
60': 1.756
1/8: .622 @ 91.20
1/4: 11.804 @ 117.09
I have some Cosworth MX-1 cams coming that should get me to the 119-120 mph trap speed range and will hopefully be enough power for 11.5's, just a matter of time!
Attached Thumbnails Evo X Drag Times list-20g-time-slips.jpg   Evo X Drag Times list-launching-strip.jpg   Evo X Drag Times list-evo-x-mr-engine-bay.jpg   Evo X Drag Times list-evo-x-mr-front-clip.jpg
Old Jul 7, 2013 | 08:16 AM
  #63
powered4B11's Avatar
12.63 @107.8 1.71 60'
Old Jul 7, 2013 | 10:18 AM
  #64
Darksun280's Avatar
Good work hiboost and powered4B11 . List updated.
Old Jul 12, 2013 | 09:47 PM
  #65
Darksun280's Avatar
XGorillaX" Another espec built EvoX went 11.056 @ 131.75 today.
Old Jul 13, 2013 | 01:20 AM
  #66
Illrunya's Avatar
Gorillax Another espec built EvoX went 11.056 @ 131.75 today.
Awesome work!
Old Jul 13, 2013 | 08:09 AM
  #67
JC7119's Avatar
Went 12.238 at Atco yesterday. 2.2L, S1 Cams E-Spec Turbo 25psi, supporting mods E-Spec Tuned.
Old Jul 13, 2013 | 08:57 AM
  #68
Darksun280's Avatar
List updated. good effort joe. Car has 11.5's in it but i know i know your 8's the race car the X is the daily lol
Old Jul 13, 2013 | 02:22 PM
  #69
NY Black momba's Avatar
great work is this guy from long island bayshore islip area in NY i feel like i have seen this car??
Old Jul 13, 2013 | 03:08 PM
  #70
E-SPEC INDUSTRIES's Avatar
We miss seeing you around Allen!! Stop by the shop and say wassup!
Old Jul 14, 2013 | 10:27 AM
  #71
ill come threw one day your shop is right around my house !!nice work with the cars you been pumping out!!
Old Jul 14, 2013 | 10:38 AM
  #72
JC7119's Avatar
I got all summer to fix my 12.2...hopefully less rain next time we go out for some thrashing lol.
Old Aug 6, 2013 | 08:14 AM
  #73
Darksun280's Avatar
Voption : 11.491 @ 120.85
Old Aug 6, 2013 | 08:41 AM
  #74
Darksun280's Avatar
OlegVR4 : 11.173 @113.52mph
Old Aug 6, 2013 | 09:08 AM
  #75
Darksun280's Avatar
3 new names on the all time list. Things just got interesting.
