New WW IX MR
Old Jun 30, 2013 | 08:18 PM
  #151
kyoo's Avatar
Some Night Shots - 06/30/2013
Can't tell at all from a normal angle that the driver's side panel was dinged!
Old Jul 1, 2013 | 03:24 AM
  #152
tscompusa's Avatar
very nice. powder coat the wheels black! black wheels with a white car is the best color combination to exist imo.
Old Jul 1, 2013 | 07:08 AM
  #153
kyoo's Avatar
lol - i'll consider it - i like the diamond black though. can't wait to get the car ready for you to continue tuning!
Old Jul 17, 2013 | 08:43 PM
  #154
kyoo's Avatar
been unbelievably busy lately, so i have hardly touched the car (hardly even been on these forums) - though i walk past it in the garage every morning, afternoon, and night. i decided to tackle one last thing left before the rear diff gets serviced for the stripped fill-hole threads:
Buschur's removable harness bar - halfway in! I ran out of time towards the end of the night to wrap up the rest (most) of it. A few things I noticed installing it this time around.
Because the threads on the bolt that go into the top portion of the seatbelt stop halfway along the way, you can't use the spin washers that lock the seatbelt part in place. When I first did this, I thought that was the reason why I lost functionality as far as being able to rotate the top portion of the seatbelt - I realize now that that is not the case. The reason I lose rotation in the seatbelt is because the washer given to go through the seatbelt is too thick, and so there's too much friction.
The second thing I noticed is that there is a lot of give in the seatbelt sliders (what lets you adjust the seatbelts up and down) and in turn there's a lot of give in the bar. I believe this was remedied last time by attaching the bottom "legs" for the harness bar. Nothing major, jsut wonder if this is the reason i still always had a little give with the harness on, and wonder how much it really does as far as chassis support goes.
Old Jan 10, 2014 | 09:15 PM
  #155
kyoo's Avatar
2014 update to say no updates... can't believe i've had this car for about a year now, i've hardly driven it
Old Jan 11, 2014 | 05:33 AM
  #156
IzzyRS's Avatar
Well, start driving it
Old Jan 16, 2014 | 01:47 PM
  #157
Danner's Avatar
Its sad to say this car has lived a very boring life. I know from experience.
Old Jan 16, 2014 | 04:06 PM
  #158
kyoo's Avatar
lmao sad but true
Old Jan 22, 2014 | 09:17 PM
  #159
Kada__85's Avatar
drive it meow!!!! a car as beautiful as that is meant to be driven
Old Apr 30, 2014 | 11:31 AM
  #160
kyoo's Avatar
you guys are gonna hate me, i still haven't done **** with this car. it hasn't been started since august - how long does a disconnected car battery last?? i'm slowly making the moves to get it up and running again.
anyone have any tips on what to do with the battery? i've got a trickle charger that does 6v or 12v, i'm assuming 12v will be appropriate. one clasp to positive, one clasp to chassis, and plug it in? do i have to check the water in the battery and stuff?
prob will do coolant flsuh and oil change before i start the car up too. it's been parked for forever but at the very least on cardboard, hopefully that helped to not flatspot the tires lol. hmm anything else? i may need to reload the tune if the car's forgotten it after all this time lol
Old Apr 30, 2014 | 12:29 PM
  #161
golgo13's Avatar
EvoM Community Team
Veteran: Navy
So, some trickle chargers won't charge if the battery has fallen below a certain amperage.
You might want to get a second battery, daisy chain it to the battery already in the car and then start the motor. From there you might want to drive it a bit to get the amperage back up before you can hand it off to your trickle charger.
Ask me how I know.
Old Jun 26, 2014 | 08:27 AM
  #162
kyoo's Avatar
gonna start this bad boy up again this weekend! i mean it this time...
i will:
- hook up to trickle overnight, otherwise just hook it up to second battery since it's parked next to the outback
- pull the plugs and spray inside with fogging oil
- change the oil just before starting it, fill up the oil filter with oil
- fire it up, fill up gas, drive it around
- get the coolant changed, add RMI, then do a proper flush at home later!
here goes nothing!
Old Jun 27, 2014 | 07:30 AM
  #163
heel2toe's Avatar
^Pssshhhh doubt it! 10 bucks says you don't fire her up this weekend
Old Jun 27, 2014 | 08:00 AM
  #164
kyoo's Avatar
haaaaa i can't take that bet lol
the only thing that will stop me is if the security system completely reset itself and i cant get the car to start bc of it lol
Old Jun 27, 2014 | 08:36 AM
  #165
heel2toe's Avatar
Haha, you're already making excuses!!!
Well, I wish you luck bud
