SAFC install with Harness help?
Old Apr 5, 2005 | 12:41 PM
binsquared's Avatar
Ive been looking through these forums and the only installation guides i found were the ones where u have to splice the wires.
Im looking for installation guide w/ the field harness. Can someone help me out?
sorry im quite clueless w/ which goes with what, which connects to which..blah blah blah...
thanks in advance
Old Apr 5, 2005 | 09:11 PM
binsquared's Avatar
bumpity bump
Old Apr 5, 2005 | 10:28 PM
EasyZ06's Avatar
From what i understand you still have to splice the fields harness for the afc. It just makes it so you do not have to splice the factory harness, and the fields can be taken out easliy.
jeff
Old Apr 10, 2005 | 01:50 PM
CLOWNY's Avatar
connect:
safc ecu pin
red 25
grenn 58
purple 78
gray 84
brown 26> conect closer to ecu
black 26> conect on same harness wire that brown is conected,
pink 90 > cut this wire in half, conect to the wire going to ecu
orange 90> connect to other half
you can get the wiring diagram from http://www.roadraceengineering.com/e...-ecuwiring.htm. ecu diagram is looked from the wires side of the plug.
Old Apr 10, 2005 | 05:19 PM
plokivos's Avatar
also, when you're doing the black and brown wires, you have to give it about 1cm or more seperation between the wires soldered.
i gave it about 3/4 of an inch between those 2 wires.
Old Apr 12, 2005 | 09:53 AM
binsquared's Avatar
cool...thanks for the help everyone
Old Aug 22, 2005 | 10:30 AM
w8less1der's Avatar
Originally Posted by CLOWNY
connect:
safc ecu pin
red 25
grenn 58
purple 78
gray 84
you can get the wiring diagram from www.roadraceengineering.com/evo/tech/EVO-ecuwiring.htm. ecu diagram is looked from the wires side of the plug.
The diagram in the SAFC wiring diagram by model appears differently. I should be looking at M5-a on page 48 in the wiring diagram by model book right?
Old Aug 22, 2005 | 11:10 AM
w8less1der's Avatar
Nevermind, Warrtalon pointed me in the right direction
