WOW ! 558 AWHP 454 awtq on stock motor (cams and headbolts) and 94 octane w/meth.
From: driving the 10 second beast in ohio or running lightmods.net
http://www.putfile.com/media.php?n=s...r-ad&width=800
new muffler ( put on after all dynoing)
http://www.putfile.com/media.php?n=s...L-muffler-ad60
What does the turbo spool up at? I notice that you don't go WOT until 4,000 RPM and reach peak torque at 5,500 RPM. Is 5,500 RPM where you hit target boost or is it before then?
Thanks,
Keith
Thanks,
Keith
on the road it spools full boost by 4500 ish if i hit it early (basically it recovers shifts fast) and drives great.
I am also drive mine around all day every day at around the same power level and boost level and have lots of 'spirited' moments
I wouldnt worry much about the motor holding at 25-26psi. The 30psi runs I would think it should take just as well.. It will not last you 100k miles but who cares anyways
It will last plenty long before you decide to build the motor I would think. I plan to run my car very shortly at the 30psi mark so hopefully we will both be runnin some tens
http://www.gscdownloads.com/evodave/
first vid is the dyno run with 558 awhp
second vid is the new muffler setup from switzer performance
Got the audio now due to a codec download.
The new muffler is an improvement over the old one, but still pretty high pitched in tone.
Can you e-mail me the AEM data log from that bonzi run? That would be great!
Thanks,
Keith
Thanks,
Keith
Originally Posted by dafarmer69
im taking bets on how long it will take till the botom end gives up.. matt does great work, but one blip from the ems and BOOM... good luck dave.. keep it together..
nah...we left the knock control on and in full effect to keep it together so that should help
