Hago injection nozzle info
Old Dec 13, 2005 | 12:37 AM
SlowCar's Avatar
Flow rate, spray pattern, droplet size.......if you are curious what your nozzle does
http://www.hagonozzles.com/documents...M%20&%20MW.pdf
Old Dec 13, 2005 | 12:55 AM
fromWRXtoEVO's Avatar
Abner,
Good info. By the way, I made a interesting discovery today. I was showing my alcohol kit to Eric(Apexmotorsports owner) and I was spraying my alcohol system for a few seconds while my car was parked.
The Upper intercooler pipe got really cold but we were very surprised when we noticed that the actual pipe was cold even a good 6 "down below the Nozzle point that means a few inches ahead of the nozzle position.
I don't know how to explain this but I thought when you spray alcohol when your car is running the actual flow of the air intake in the upper intercooler pipe wouldn't allow the actual alchol to travel against the direction of the flow.
Old Dec 13, 2005 | 04:56 AM
SlowCar's Avatar
when your car is idling, the velocity/amount of air going thru the UICP(finally got it right!) is very low......allowing the "hollow cone" pattern to fully develope.
When you spray at your >15psi set point.......the fast moving air stream will push the mist forward.
Old Dec 13, 2005 | 11:36 AM
Richard L's Avatar
I sometimes wonder how the dynamic range can be improved with a pump pressure driven system, if flow only doubles when pressure is increased 4 fold.
Richard
Old Dec 13, 2005 | 05:22 PM
SlowCar's Avatar
liquid properties like density, viscosity...would have to be reduced....................
just add more nozzles
Old Dec 14, 2005 | 05:20 PM
Richard L's Avatar
I have transferred the Hago's flowrate against pressure for easy viewing.
Old Dec 14, 2005 | 05:58 PM
SlowCar's Avatar
Jameson_IXMR
21
Dec 11, 2016 07:33 PM
QwikEVO
Aug 16, 2015 11:25 AM
90GSXDan
17
Nov 29, 2008 12:36 PM
Noe18
Feb 2, 2008 11:30 AM
SlowCar
Aug 10, 2007 05:11 AM
