Enkei RPF1 17x9.5 Pictures and Weight
Old Jan 25, 2006 | 09:31 PM
  #46
joeymia's Avatar
Originally Posted by evodave
can you get a bunch more pics and side pics to see all around and a shot to see how far they stick out. Did you get 3/4 inch spacers then?
Dave
I got the Kics 15mm spacers but I am going to add an extra 2mm one. The caliper is kind of close I'll take better picture tomorrow in the day.
Old Jan 25, 2006 | 09:34 PM
  #47
joeymia's Avatar
Dave
If these spacers work out I was thinking of using a set on the rear and getting wider rear fenders. I think it would give it a unique look.
Old Jan 26, 2006 | 02:39 PM
  #48
tbizzy85's Avatar
I like the extreme close up on the Black Razor
Nice wheels what's the offset?
Old Jan 26, 2006 | 03:24 PM
  #49
SS RX7 r2's Avatar
Originally Posted by joeymia
it protrudes a bit out of the fender but the driveside tire was slightly turned aswell.
The set-up on my car seems to sit inboard quite a bit more than yours, even with wider .75" spacers. I thought it may be due to more neg camber on my car, but I had another thought.
I max out the camber plates full neg, then use the stock adjustment bolt to add back some pos camber. This may position the whole assembly further inward.
The dark wheels look nice
Old Jan 26, 2006 | 04:08 PM
  #50
smokeyonline's Avatar
Originally Posted by 'ringmeister
6 lbs!? stop buying wheels and feed the cat
That's funny
Old Jan 26, 2006 | 06:03 PM
  #51
zhangzheng's Avatar
how much for all 4 and what's the offset?
Old Jan 26, 2006 | 07:28 PM
  #52
joeymia's Avatar
The four wheels were around 1080 which I was able to pickup locally from www.edgeracing.com. I called them to see how much shipping was and the guy was like "dude your like 10 minutes from here". They are 17x9.5 with a 38 offset. The 15mm spacer clears the caliper but they are kind of close. Like robi had mentioned 17mm would be the ideal spacer you should get.
Old Jan 27, 2006 | 12:59 PM
  #53
joeymia's Avatar
DO NOT USE A 15MM SPACER
Today while driving once everything heated up etc.. my caliper started rubbing against the inside spokes.
Old Jan 27, 2006 | 01:46 PM
  #54
robi's Avatar
that's why I use 20mm adaptors
Old Jan 27, 2006 | 01:49 PM
  #55
b1keguy's Avatar
paint
What kind of paint di dyou use?
Old Jan 27, 2006 | 02:37 PM
  #56
eddie's Avatar
I have a set of 17 by 9.5 RPF1's with a 38 offset (powdercoated black) that came off my 350z but they won't clear the front Brembo's.
Nice wheels!
Old Jan 27, 2006 | 02:47 PM
  #57
eddie's Avatar
Originally Posted by robi
Enkie's engineered specs are 17mm spacer...RPF1's do have alot of spoke flex with high grip/high HP cars...
Word.......I broke one of them at Buttonwillow last year. Only 3 of the split spokes held, preventing the wheel from coming off completely. Sure banged the sh#t outta' my Brembo caliper through. (this was on my old 350Z).
Old Jan 27, 2006 | 02:53 PM
  #58
marksae's Avatar
Dang, these wheels seem to be questionable strengthwise when used at the track.
Old Jan 27, 2006 | 04:09 PM
  #59
robi's Avatar
NTO3+M (I'm doing a group buy...) 1mm off rear caliper on 260x650 slicks @ 145 MPH at Cal speedway 3100 lb car, turn 1&2 ZERO flex!
Old Jan 27, 2006 | 04:13 PM
  #60
eddie's Avatar
Nice...what kind of price are we looking at for the group buy?
