warped rotors again. ?shaving again
Well at 15000 miles my rotors started to warp. I got them resurfaced by the dealership. At the time they said that my pads looked good and I didn't need to replace them. Now at 20,000 miles it came back. Went to the dealer and they reccomended resufacing and changing pads. They assured me if I did this the rotors wouldn't warp again. I was going to have them put on the ferodo ds 2500 pads, since they said the pads aren't covered under warranty. They won't replace the rotors only resurface. Am I a fool for doing this, or can the resurfacing and new pads solve my problem. Thanks for the input.
To bed in the pads take the car up to 60mph and do a few hard brakes. If 100% = antilock brakes kicking in take it down to 80%. Do that about 6-7 times without ever coming to a complete stop. After you have done it a few times drive around to get the brakes to cool down then see if the shimmy is still there. If you feel less vibration than before bed the brakes in some more.
Every time you resurface the rotors, the removal of material makes them more prone to warping in the future.
I would, as other members suggested, look into uneven pad transfer as the culprit and, if addressing that doesn't work, replace (not resurface) your rotors.
Here is a quote from Chronohunter (professional driver who is a member on this board) regarding brake pad material transfer problems:
"You can clean them (or cook them clean) by heating them up to the point of light fade and then slow the car to a stop using no brakes if possible, you must coast the last foot with out ANY brake then kill the car in gear (no hand brake) and let it cool all the way down (1/2 hour or so). Now drive away and your "warped" rotors have magicly straightened . You can repeat this as many times a necessary over the life of the pads. Next time get some Ferodos/ Hawks/Pagids which don't have transfer issues."
I've just had my rotors treated for the 3rd time... (~20,000 miles). First time the rotors warped they decided to skim them. I expressed concern as that makes them more likely to warp. A few months later they were warped again. Took it back to the dealer who replaced the rotors. They wanted to charge me for new pads but after some arguments they replaced those too (car was <12 months old at that point).
Then a few months ago the rotors warped again.. took the car back and they wanted to discuss with Mitsubishi before replacing. After a few months they phoned me back and said they would replace them. Just got the new ones fitted again...
There seems to be some fundamental issue with the rotors... I know a lot of my Evo friends in the UK have had issues. They told me it was somethign to do with the way they were fitted and not a manufacturing defect...
Who knows - I just want to see if they warp again before the end of the warranty. If they do then I'll start to make some serious noise down at the dealer...
The only reasonable advice here is what dpardo said.
First look into the brake pad transfer issue (or chatter). If thats not the prob. then...
If they've been resurfaced already - get brand new pads and brake new rotors.
Like dpardo said: resurfacing again will only make them thinner and will "warp" even faster.
Thanks. I tries rebedding with braking technique, and it was no help. I will try to talk to my dealer about getting to rotors, but they wouldn't when asked the first time. I guess if they refuse to get me new ones, I'll try to resurface them again with the new ferodo pads I got. I'll ask for a garantee in writing for the life of the pads. Anyone know another way to get the dealer to replace the rotors vs. resurfacing again.
Cutting into the rotor is a temporary fix for warped rotors. I would not recommend it for a high performance car like the Evo. The rotors will thin out quite a bit and warp again within 3 to 5k miles. I have a dreading personal expereince with this problem and the only way to get rid of warp rotors is to replace them.
Thanks,
Tom
Thanks,
Tom
EVOtook
46
Apr 10, 2004 04:24 PM
sanjaya1
18
Dec 27, 2003 06:12 AM
amigoni
14
Aug 26, 2003 10:14 AM
