Drop in air filters: Un-confuse me please
Old Apr 27, 2006 | 12:48 AM
  #31
badhabit90's Avatar
WORKS-talk to Jamie. he can hook you up.+5 on the filter. well worth the wait. you wont be disappointed.
Old Apr 27, 2006 | 05:52 AM
  #32
Jussb1aze's Avatar
I got the blitz drop-in have been running it for 2 months now and haven't had a single problem. Noticed an immediate increase in throttle response.
Old Apr 27, 2006 | 10:10 AM
  #33
azredevo's Avatar
how about filtration abilities of the blitz... i'm concerned about the hks i have after reading all the posts. i need something to keep all the arizona dust out.
Old Apr 27, 2006 | 10:46 AM
  #34
ZK's Avatar
ZK
I have the Blitz LM filter. Been 8 months so far and runs good. The Blitz is a DRY COTTON filter so no worries about oil gunking up your MAF sensor.
Filtration is not going to be as good as the stock paper one - but then no aftermarket high flow filter is. Your best bet if you want the best filtration is to keep the stock paper filter. Just adding a drop-in air filter does very little in terms of performance without a tune.
Look at this filter test:
http://www.mkiv.com/techarticles/filters_test/2/
The best filter in this test was the Apexi - which is a dry cotton filter. It filtered the best while still offering good airflow.
K&N and Works are both oil-type filters and I would not want oils coating my MAF sensor.
Old Apr 27, 2006 | 04:52 PM
  #35
G20's Avatar
G20
I'm using K&N for 3 years on both my EVOs and no problem or what so ever. It even withstand a sand storm that I encoutered while driving through Arizona last year.
As long as you don't "deep fry" the filter with oil, it should be ok.
Old Apr 27, 2006 | 07:03 PM
  #36
azredevo's Avatar
"sand storms" are the norm out where I live... so it needs to withstand that... may go back to stock...
Old Apr 28, 2006 | 12:09 PM
  #37
Jamie@WORKS's Avatar
Originally Posted by jrsimon27
what gains in horsepower can one expect from a drop in air filter??
thanks
I don't have HP figures (although some of our customers have posted results elsewhere), but I do have some other numbers. We tested four various filters (stock, a leading foam filter, a leading competitor's filter, and the WORKS filter) using a Superflow Flowbench.
Not surprisinginly (in my biased mind anyways ), the WORKS filter came out on top. What was surprising is how much on top it was. Our filter outflowed the stock unit by 240%, the foam filter by 200% and our competitor by 150%. All testing was back-to-back-to-back-to-back within moments of each other.
They are worth the wait and we should have them back in stock very soon. Give us a call if you want your name added to our waiting list. Thanks!
Old Apr 29, 2006 | 07:31 AM
  #38
Greg Haymann's Avatar
K+N style filters flow 8% better when new,but allow 200% more particles through the intake.After 5K equals paper.This study was done on a BMW 535 model 89.
Old Apr 29, 2006 | 04:20 PM
  #39
kf6ytc's Avatar
None of the dropins on the market will make a significant power increase, so buy the one that has the color you like most
Old Apr 29, 2006 | 10:27 PM
  #40
Syrihl's Avatar
The Works filter is probably one of the best drop-in types, easily >30% more surface area than K&N's with a similar filter material. If anyone is looking for one, I've got one for sale here: https://www.evolutionm.net/forums/sh...t=works+filter
Old Apr 30, 2006 | 02:25 AM
  #41
azredevo's Avatar
I just swapped out my hks drop in for a blitz and cannot believe the difference. Sounds a bit rice, but the gains in performance are AMAZING! I bought it on the spot.
Old Apr 30, 2006 | 05:50 AM
  #42
k270kmh's Avatar
I think that doesn't matter how much in % one filter is able to flow more than another, the point is: how much does your engine need?
Old Apr 30, 2006 | 10:56 PM
  #43
kf6ytc's Avatar
gains? where are the dyno plots?
Old May 1, 2006 | 12:30 AM
  #44
azredevo's Avatar
i'm doing a complete tune on tuesday, getting the exhaust put on too, i'll throw the stock one back on, and see what i get compared to the blitz
Old May 1, 2006 | 04:54 AM
  #45
Talon's Avatar
I have the Green.
