post alky timing maps please
Old May 4, 2007 | 01:43 PM
  #46
esevo's Avatar
Abner knows his stuff on alky!!!!
Old May 11, 2007 | 10:19 PM
  #47
Jeff_Jeske's Avatar
Here is my alchy map. I have spray coming on at 15psi maxing out at 20psi. My boost is spiking to 26psi and holds 24psi through most of the midrange. I have zero knock and I am seeing a load as high as 255. My afr is tuned for 11:1.
This map took me 3 days to build. It basically a drag race map with 2* less than what I could run before I would see a little knock. I believe it will be safe in all weather conditions. The best part is turning down the boost makes the same map safe for road racing.
Old May 12, 2007 | 12:07 PM
  #48
05BlackEVO's Avatar
This is good stuff.
Old Jun 20, 2007 | 08:18 AM
  #49
bnice01's Avatar
boost @ 24ish 8*@ peak and 15* @ 7k (shift point) still really pig rich (11.3 peak and 10.4 redline) 0 knock. wideband took a crap on me so I cant log but I am using my narrowband while its getting fixed (just to monitor not to tune) but plan to raise it more once I lean it out. I run 100% all the way baby. you can get knock from running to much fuel:
By Klaus Allmendinger, VP of Engineering, Innovate Motorsports
Many people with turbochargers believe that they need to run at very rich mixtures. The theory is that the excess fuel cools the intake charge and therefore reduces the probability of knock. It does work in reducing knock, but not because of charge cooling. The following little article shows why.
First let’s look at the science. Specific heat is the amount of energy required to raise 1 kg of material by one degree K (Kelvin, same as Celsius but with 0 point at absolute zero). Different materials have different specific heats. The energy is measured in kJ or kilojoules:
Air ~ 1 kJ/( kg * deg K)
Gasoline 2.02 kJ/( kg * deg K)
Water 4.18 kJ/( kg * deg K)
Ethanol 2.43 kJ/( kg * deg K)
Methanol 2.51 kJ/( kg * deg K)
Fuel and other liquids also have what's called latent heat. This is the heat energy required to vaporize 1 kg of the liquid. The fuel in an internal combustion engine has to be vaporized and mixed thoroughly with the incoming air to produce power. Liquid gasoline does not burn. The energy to vaporize the fuel comes partially from the incoming air, cooling it. The latent heat energy required is actually much larger than the specific heat. That the energy comes from the incoming air can be easily seen on older carbureted cars, where frost can actually form on the intake manifold from the cooling of the charge.
The latent heat values of different liquids are shown here:
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
Methanol 1109 kJ/kg
Most engines produce maximum power (with optimized ignition timing) at an air-fuel-ratio between 12 and 13. Let's assume the optimum is in the middle at 12.5. This means that for every kg of air, 0.08 kg of fuel is mixed in and vaporized. The vaporization of the fuel extracts 28 kJ of energy from the air charge. If the mixture has an air-fuel-ratio of 11 instead, the vaporization extracts 31.8 kJ instead. A difference of 3.8 kJ. Because air has a specific heat of about 1 kJ/kg*deg K, the air charge is only 3.8 C (or K) degrees cooler for the rich mixture compared to the optimum power mixture. This small difference has very little effect on knock or power output.
If instead of the richer mixture about 10% (by mass) of water would be injected in the intake charge (0.008 kg Water/kg air), the high latent heat of the water would cool the charge by 18 degrees, about 4 times the cooling effect of the richer mixture. The added fuel for the rich mixture can't burn because there is just not enough oxygen available. So it does not matter if fuel or water is added.
So where does the knock suppression of richer mixtures come from?
If the mixture gets ignited by the spark, a flame front spreads out from the spark plug. This burning mixture increases the pressure and temperature in the cylinder. At some time in the process the pressures and temperatures peak. The speed of the flame front is dependent on mixture density and AFR. A richer or leaner AFR than about 12-13 AFR burns slower. A denser mixture burns faster.
So with a turbo under boost the mixture density raises and results in a faster burning mixture. The closer the peak pressure is to TDC, the higher that peak pressure is, resulting in a high knock probability. Also there is less leverage on the crankshaft for the pressure to produce torque, and, therefore, less power.
Richening up the mixture results in a slower burn, moving the pressure peak later where there is more leverage, hence more torque. Also the pressure peak is lower at a later crank angle and the knock probability is reduced. The same effect can be achieved with an optimum power mixture and more ignition retard.
Optimum mix with “later” ignition can produce more power because more energy is released from the combustion of gasoline. Here’s why: When hydrocarbons like gasoline combust, the burn process actually happens in multiple stages. First the gasoline molecules are broken up into hydrogen and carbon. The hydrogen combines with oxygen from the air to form H2O (water) and the carbon molecules form CO. This process happens very fast at the front edge of the flame front. The second stage converts CO to CO2. This process is relatively slow and requires water molecules (from the first stage) for completion. If there is no more oxygen available (most of it consumed in the first stage), the second stage can't happen. But about 2/3 of the energy released from the burning of the carbon is released in the second stage. Therefore a richer mixture releases less energy, lowering peak pressures and temperatures, and produces less power. A secondary side effect is of course also a lowering of knock probability. It's like closing the throttle a little. A typical engine does not knock when running on part throttle because less energy and therefore lower pressures and temperatures are in the cylinder.
This is why running overly-rich mixtures can not only increase fuel consumption, but also cost power.
I only had my 8 for two weeks LOL
Old Jun 20, 2007 | 08:52 AM
  #50
bnice01's Avatar
Originally Posted by gunzo
And this is for implying I'm a liar that I run 2bar at 23-25degrees
nice dude but do you shift @ 7800 when you run?
i shift around 7k and feel like its falling on its face @ past that but LMK
Old Jun 21, 2007 | 02:06 AM
  #51
gunzo's Avatar
I shift at 8k rpms .. peak power is at 74-7500rpms .. just nice for a 8k shift point
Mine is used for autoX so it's slightly different if you're talking about drag..
zbomb
Jan 3, 2010 10:47 PM
tuner
27
Dec 29, 2006 12:52 PM
1BlackEvo9
Jul 22, 2006 03:18 PM
justchil
Jun 22, 2006 10:46 AM
Derek888
37
Dec 12, 2005 07:32 AM
