All headgaskets are not created equal
Old Feb 4, 2008 | 03:29 PM
Vapor's Avatar
used the cometic gasket on my sr20 240sx. Lasted for 3k miles then pushed coolant, running about 20psi on GT2540R (~400ish whp). Apex-i headgasket is very nice too, if they make it for SR's
Old Feb 4, 2008 | 07:09 PM
vwjeff's Avatar
Cometic on my VW... leaked everything
That Cosworth head gasket looks nice
I feel that surface prep determains how well things will seal.
Old Feb 4, 2008 | 07:20 PM
2k4EvoVIII's Avatar
I would like to see the Power Enterprises head gasket tested also. Then all the major gaskets would have been tested. I believe the film is $57 a foot which i would be willing to help pay for whatever to get this one tested. Since its the only headgasket along with Cometic it leaves the guys with a 87mm bore not many options.
Chris
Old Feb 4, 2008 | 08:22 PM
CO_VR4's Avatar
Felpro makes a nice gasket for the DSM. Anyone used it on the Evo yet?
Old Feb 4, 2008 | 08:27 PM
kimchee's Avatar
really interesting stuff, awesome info
Old Feb 4, 2008 | 08:28 PM
BBS's Avatar
BBS
repost. Kick *** blog though (Eric's.)
Old Feb 4, 2008 | 08:42 PM
4G63-KID's Avatar
that cosworth looks really nice. oem looks pretty good too and that cometic one looks like pure s**t. I bet some black silicone would work better than it
Old Feb 4, 2008 | 08:52 PM
JC evo1's Avatar
looks like someone went over the cosworth in photoshop to me
Old Feb 5, 2008 | 05:14 AM
tkklemann's Avatar
Was the OEM tested a VIII or an XI headgasket?
Remember, the VIII is a 3-layer and the XI is a 5-Layer headgasket.
I bought an OEM XI for my VIII instead of getting a Cometic because of the 5-Layer Design.
Last edited by tkklemann; Feb 5, 2008 at 05:15 AM. Reason: Because I love your mom.
Old Feb 5, 2008 | 06:39 AM
JC evo1's Avatar
how did you get a evo 11 gasket? lol
Old Feb 5, 2008 | 08:35 AM
tkklemann's Avatar
I went 88mph, that's how...
Old Feb 8, 2008 | 05:08 PM
JKav's Avatar
It was a IX gasket (5 layer). I just confirmed with Eric.
He tested the VIII gasket (3 layer) too and said it was ever so slightly lighter than the IX in between cylinders.
Old Feb 8, 2008 | 05:29 PM
lemmonhead's Avatar
more layers is not necesarly better. thicker head gaskets could cause problems by adversely changing the geometry of the head-block interface on the intake manifold , this is on Vee-type engine though.
But for out inline engines it could also subtly alter cam timing. but worst of all it could degrade the squish effect in the combustion chamber which can be greater pro-knock factor!!
your best bet is to o-ring they cylinders by machining a shallow groove into the fire-ring area of the block or head around each cylinder bore then installing gapless machined-steel rings or steel wire into the groove.
Old Feb 8, 2008 | 07:42 PM
Whoop_ass's Avatar
greg from GSC also recommends the stocker
OEM FTW!!!!
Old Feb 8, 2008 | 07:57 PM
David Buschur's Avatar
The Cometic sucks I've said it for years, the FelPro sucks just as bad, maybe even worse than the Cometic. You don't see those on our website do you?
Eric Hsu is a good guy, known him a long time. Well respected guy.
We use the stock 3 layer EVO8 gasket, 50+ psi of boost, no problems.
