Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
BC racing coilovers
Old Mar 4, 2008 | 11:58 AM
ohheyitzjon's Avatar
BC racing coilovers
just saw this:
https://www.evolutionm.net/forums/sh...d.php?t=226733
Evo X coilovers... what do you guys think? Good for a daily driver? has anyone had any experience with these coilovers?
Old Mar 4, 2008 | 12:30 PM
DirectorSe7en's Avatar
Hmm, I'd like to see one installed on an X.
Old Mar 4, 2008 | 01:38 PM
iamdace's Avatar
id like to see some shock dyno graphs
Old Mar 5, 2008 | 07:04 PM
dbotkin5's Avatar
dyno graphs??
Old Mar 5, 2008 | 07:38 PM
billyblonco's Avatar
Lets strap those babies on the dyno and see how much hp they give you
Old Mar 5, 2008 | 08:15 PM
robi's Avatar
Shock dyno...or how the damping curves compare to what is needed for the X. This is a SINGLE adjustable shock with 30 whatever clicks... I can already tell you the 6K spring is too soft for the wheel weights this car puts down. I would also like to see the wheel travel with this system as the SAWC does all kinds of funny things when you start lifting wheels.....
Old Mar 11, 2008 | 01:55 PM
IMPORTIMAGE's Avatar
should have some info this week with pics etc for you guys
I'll get the dynos, not everyone can afford 3k kits for street use and would utilize it either.
we do custom valve kits with custom rates for those who do want to do more tracking
Old Mar 11, 2008 | 02:31 PM
So can you negatively effect the SAWC by getting lowering springs over coilovers?
Old Mar 11, 2008 | 02:53 PM
GTWORX.com's Avatar
^ The issue is travel....if you do not have enough droop you can lift a wheel in corners which may make the diffs freak out. Not sure how the X will react. Really grippy tires + soft springs might also do it.
Plus ride quality suffers with short travel suspensions.
- Andrew
Old Mar 11, 2008 | 04:02 PM
EVOX08's Avatar
+1
Old Mar 19, 2008 | 03:37 PM
Danny@BC's Avatar
Some of our vendors mentioned that you guys were requesting shock dynos so here are the graphs for the Evo X:
Front graph:
Front full hard
Front full soft
Rear graph:
Rear full hard
Rear full soft
Old Mar 19, 2008 | 05:37 PM
34Turbo's Avatar
I had BCs on my IX and they were ok. I wasn't too impressed though...
Old Mar 20, 2008 | 03:47 PM
rijowysock's Avatar
the BC's ride great, i helped install and also test drove the first set of BC's on a 10 the other day from logan @ darkside Engineering... they rode great!
https://www.evolutionm.net/forums/sh...d.php?t=333283
spring setup seemed like was too low... 8/6 but rode great,... props to BC
Old Mar 21, 2008 | 08:07 AM
car looks great!
Old Mar 29, 2008 | 07:40 PM
GTWORX.com's Avatar
Front graph:
Front full hard
Front full soft
Rear graph:
Rear full hard
Rear full soft
Finally got a chance to look over the graphs.
This is with 8k/6k springs correct?
- Andrew
