HowTo: Identify Diagnostic Cables by PinOuts.
Old Jul 23, 2008 | 11:37 AM
evo828's Avatar
Connected pin 1 to pin 15 on the cable side.
AYC connects and logs = however the data is not changing ie doesnot makes sense - turning wheel doesnot chenge the angle etc.
ABS - is not able to establish a continuing connection - no logged data
Engine on - but car was not moving. I haven't tried the actuators.
Old Jul 23, 2008 | 12:26 PM
jcsbanks's Avatar
Same as me. I think Hamish needs to go back to the drawing board for Evo 7-9 AYC logging?
Old Jul 23, 2008 | 12:39 PM
evo4mad's Avatar
nope, it works perfect I have had hundreds of success reports.. I never said connect pin 1 to 15 on the cable side, thats absurd, you are basically connecting pin 15 to ground by doing that, thats the last thing I said to do. I said to put pin 1 on the vehicle side into pin15 slot on the vehicle side.
Old Jul 23, 2008 | 12:45 PM
evo4mad's Avatar
yep perfect... you've got it.... on the latest cables, I hope I dont confuse anyone, but how the evoscan cables now are - they have pin1 disconnected from ground on the cable, and instead pin15 and pin1 are connected. So only do this if you have continuity between pins 1 and 4 on your cable side. those that have continuity between pin 1 and 15 on the cable side then you I have already done for you, and you don't have to do anything except perhaps remove the subaru pin9, which interferes with mitsubishi diagnostics and should be removed from the cable side.
Originally Posted by evo828
based on what I understand what Hamish is proposing - you need to get the pin 15 on the cable plug to connect to pin 1 on the car side. So connecting 4 and 15 on the cable side will not help.
try to move pin1 into pin15 on the car side (female) connector.
Old Jul 23, 2008 | 12:50 PM
evo4mad's Avatar
pin9 is connected to pin15, so you don't want to be sending signals to the ETACs at the same time, else it disconnects the AYC/ABS ecus from communicating.
Old Jul 23, 2008 | 12:51 PM
evo4mad's Avatar
what was the ecuid you received jcs? I can check the request ids are correct for your model.
Old Jul 23, 2008 | 01:03 PM
jcsbanks's Avatar
I cannot get the pins out of my car's OBD connector even removing the grey holder and then trying to get it out with watchmaker's screwdrivers. This is why I have tried by connecting pin 1 to 9 (9 and 15 are connected in my Tactrix cable - they continuity test and it shows on the wiring diagram). I will get the ecuids for AYC and ABS and post them. I had to cut the connection to pin 9, but again this made no difference so I've resoldered it again. I could log TPS through request ID 1C on the AYC so something is working...
Am I wasting time trying to get this to work with a Tactrix cable? If your cable will fix this I'm happy to order one, but no point if I just get the same problem. Or is your cable just twiddling the same K & L lines as Tactrix with the L line moved to pin 1?
Old Jul 23, 2008 | 01:18 PM
jcsbanks's Avatar
AYC ecuid is 6201
I get "Error: Index was outside the bounds of the array" if I try to log TPS on 1C, but I can do it from the custom requests.
ABS:
Info: Initialize Vehicle ECU...
Info: ECU ID: B063
Info: Connection successful...
[Immediately followed by...]
Info: Datalogger Ended.
I know this isn't an open source project, but I'm completely in the dark to debug this as I don't know how the hell it all works apart from studying the wiring diagrams.
Old Jul 23, 2008 | 01:29 PM
jcsbanks's Avatar
Are 6201 and B063 the echo of wake up for each ECU or do they appear to be genuine ecuids?
Old Jul 23, 2008 | 02:13 PM
evo828's Avatar
My fault - but now I tried it exactly as you said - moved the pin on the car side - from pos 1 to pos 15.
the same scenario - AYC connects and logs - but the values do not change
ABS the same behaviour as with john - connects and immediatelly disconnects.
the ecu ids are the same as john is mentioning - (but I have a EDM Evo 8 vs his Evo 9) so I am surprised they show the same ID.
Old Jul 23, 2008 | 06:03 PM
evo4mad's Avatar
they are actual perfect genuine ecuids, same ecu ids as in my 1996 Evo4 so they have reused the same ABS and AYC ecus for a number of models by the looks.
Old Jul 23, 2008 | 06:04 PM
evo4mad's Avatar
I'm not surprised, Mitsubishi just hasn't changed AYC/ABS ecus for a number of years by the looks.
Old Jul 23, 2008 | 06:07 PM
evo4mad's Avatar
you've got it right, my cable is twidlling the same K & L lines as Tactrix with the L line moved to pin 1. (my cable has L Line connected to both pin1 and pin15)
mitsubishi pin 9 ETACS is a 5volt TTL line, so putting the 12-14volt L line(subaru pin9) onto it is not the best idea, but doesn't harm anything.
I am looking at supporting the older TTL ecus used in the EVO8/9 by creating a new cable with pin9 as a TTL line.
Old Jul 23, 2008 | 06:09 PM
evo4mad's Avatar
There is no point you wasting your time debugging sourcecode, I can fix it easy as, now that you have posted the results. I'll take a look at it this afternoon. to see any reason why you are getting what you are both getting.
AYC ecuid is 6201
ABS:
Info: ECU ID: B063
Old Jul 23, 2008 | 06:11 PM
evo4mad's Avatar
maybe on the vehicle side make sure you only have the orginal pins 1/4/5/7/16 connected up and nothing else.
the other lines might be interferred with by the Subaru pins on the openport cable.
there are other ecus on the other pins like ETACs that can interrupt pin1 for all the ecus.
