rear strut bar question
Old Oct 29, 2008 | 11:06 AM
soulesswarrior's Avatar
ok i have the sub pakage in my car but i want to add a rear strut bar. i can just relocate the sub for this no?
Old Oct 29, 2008 | 05:51 PM
joeyj's Avatar
you can, and are going to have to move the sub, I have after market subs in my ra, I just have them out of the way of the strut bar.
Old Oct 29, 2008 | 06:33 PM
Pin2Win's Avatar
You can but honestly man for how cheap it would be you could slap an aftermarket sub in there for probably under $100 with box and sub. ABC Warehouse is the place to go if you have one around home. Easy way to get started on your own audio for cheap.
I dunno if you can do this on the RA but you probably could take the wires that are run to the stock sub and run them to the aftermarket one so that way you dont have to buy an Amp. I did it in my Explorer and it sufficed until I could get an aftermarket amp.
Just food for thought...
Old Oct 29, 2008 | 09:01 PM
well i do have a amp i gotfor free from a friend as well as a 10 inch sub. dunno how good they are
Old Oct 30, 2008 | 05:56 PM
silversleeper's Avatar
i found a way to remount the stock box and it does not move at all. While home on leave from Iraq and my last 3 days I went ahead and put all my suspension pieces on, you got to tap into the speaker wires and make a exstend the wires but not to bad i dont think. its as simple as taking off two brakets and using one self tapping screw for metal and a screw driver lol. It was a last minute thing sooo i didnt get the carpet and stuff put back the way i wanted to. will do that when i get back home again.
Attached Thumbnails rear strut bar question-small_100_0665.jpg   rear strut bar question-small_100_0664.jpg
Old Oct 30, 2008 | 07:57 PM
whoa the stock sub is just curves like that?
Old Oct 30, 2008 | 11:55 PM
yea it actually mounts where the strut is, the wheel well inside the trunk sooo yep, it curves like that lol. basically i just turned it and took off the other brackets and screwed it into the bottom of the trunk, doesnt move or anything. The trunk hangers just miss it to when you close the trunk. You just got to exstend the speaker wiring lol.
Old Oct 31, 2008 | 12:19 AM
well that will be a quickfix till i star putting in a diff sound system thanks for the input!
Old Oct 31, 2008 | 01:01 AM
not a problem. its just a quick fix for me till i can make something to go back there, not really into systems but do want to put in a new deck ect. I MIGHT put in a totally new system and if i do it will be because i cant use what i got now. the rear speaker will bet replaced eventually but this will work till i get home permanatly from Iraq and actually have time to work on it.
Old Nov 3, 2008 | 10:23 AM
ok it seems i have a diff speaker... i have one thats much bigger and takes up that whole spot where ur speaker curves around.
ExtremeDSM
16
May 11, 2017 10:39 PM
ExtremeDSM
35
Feb 27, 2017 06:54 AM
PDXRalliArt
Lancer Vendor Classifieds
13
Dec 27, 2004 08:29 AM
mitsumichael7
Mar 1, 2004 06:35 PM
SilverRally
16
Sep 1, 2003 10:05 PM
