Stock AMS Presents: Stock EVO X MR vs New Ralliart ECUTeK Tuned
Old Jan 16, 2009 | 09:55 AM
Chris@AMS's Avatar
Originally Posted by de_pellerin_luc
Just a tune? That's fantastic!
Tune only in the first post!
Originally Posted by STi2EvoX
What did the RA dyno at stock on your dyno? I'm curious as to what the gains were. Also, can you overlay a graph of a stock GSR as well, since it should be putting down about 10-15 whp more than the MR? Thanks.
The stock run is in the first post pictured against the 'tune only' run. The GSR run is not such a fair comparison because of the transmission differences.
Originally Posted by xbox4414
LOL what is "just a tune" MR laying down?
I don't have any of those for comparison, but I see your point!
Originally Posted by Guerillah
Show AFR data on the sheet.
I don't have it, and you don't need it. 11.4:1.
Originally Posted by SiC
How far off was the load when you changed the intake from stock to the AMS one? From my exp with the AMS intake and the JDM EvoX, I would hit 10-15% lower absolute loads causing me to run around 0.3-0.5 leaner AFRs and around 2-3 degrees increasing in IGN timing. Are you getting similar results with the RA?
The load values are significantly skewed. Using the tables available in ECUTeK I able to properly rescale everything so that I can use the factory load ranges. The intake is the source of some good horsepower gains even with the stock BCS and only 11lbs up top. There is a significant increase in horsepower, half of which is most likely attributed to the intake system.
Old Jan 16, 2009 | 10:03 AM
Chris@AMS's Avatar
Here is the chart showing the comparison of Tuned only VS tuned with the minor bolt-ons we made.
Old Jan 16, 2009 | 11:05 AM
94AWDcoupe's Avatar
cars are seriously de-tuned. what was done to achieve this?
Old Jan 16, 2009 | 11:18 AM
Chris@AMS's Avatar
The only modifcations are:
AMS Upper intercooler pipe
AMS Front mount intercooler
AMS Intake pipe kit
AMS Custom tune
Old Jan 18, 2009 | 09:10 PM
Deepseadiver's Avatar
Very good numbers, Now that I have a FP Red for my EVO X, and a new exhaust mani. How much more power do you think the RA will put down with a EVO X stock turbo?
Old Jan 19, 2009 | 09:28 PM
94AWDcoupe's Avatar
AMS Intake pipe kit
AMS Custom tune
what I meant was what did mitsu do to detune the 4b11.
Old Jan 19, 2009 | 10:01 PM
SiC's Avatar
SiC
Smaller turbo & intercooler, and not completely verified but may also have smaller injectors/pump.
Old Jan 19, 2009 | 10:06 PM
GST Motorsports's Avatar
Also more restrictive airbox, plastic bov (like 03-05 USDM Evo).
Old Jan 20, 2009 | 07:40 AM
Chris@AMS's Avatar
I can only estimate at this point, but I think that if you bolt all of the EVO X parts on, the power output should be similar to an EVO X MR.
Chris@AMS
72
Jan 5, 2010 01:32 AM
Chris@AMS
Automotosports - Illinois
10
Aug 22, 2009 10:03 PM
Chris@AMS
Jul 6, 2009 07:31 AM
Chris@AMS
Feb 22, 2009 02:04 PM
Chris@AMS
Jan 16, 2009 10:35 AM
