Aquamist HFS-5 will be replaced by HFS-6 in2009
New version of the spreadsheet.
This version also has notes explaining what each adjustment does. Hover the mouse curser over each adjustment cell to learn its function.
Right Click Save As
http://www.skidmore.edu/~a_blaker/Ca...Calculator.xls
Right Click Save As
From looking at this thread it seems like the JDM map sensor is not in fact 0-5v but rather 0-3.5v or so.
Do you agree or am I understanding it incorrectly?
Good thinking.
IE: the final values in each field may correspond to the maximum that the ecu is expecting in a lookup. so 4.98v could be ~3psi stock, and 3.63 corresponds to ~3psi on the JDM MAP (and are only relative to EGR functions/DTC). You could use the different evoscan formulas for stock MDP/MAP and JDM MAP to probably come up with a solution. I'll take a look in a minute...
Hrm, I think I may have been wrong in how I was thinking those tables worked before I actually looked at them. I'm guessing they don't define the actual voltage, but rather interpret what the ECU should expect at a voltage/pressure.
I'm not sure if there is an easy way to find out how the ECU interprets psi-> voltage -> int though, so I may have just lead you in the wrong direction.
In any case, if you can find that out you can pick a voltage, solve for X (the smallint) and then just pop it into 0.19347*x-14.3. (and replace 14.3 with your local standard atmosphere). Just by nature of the equation if 5V=255 as the ECU interprets it, that gives the JDM MAP a Maximum value of ~35.03 psi @ 14.3 std atm. If we assume it is really only good to ~31psi at 14.5 psi std ATM and assume voltage is linear then you could use 224 as max X and just solve for:
0.19347*(V*45)-14.3
But I'm guessing the actual results are not as close to that as you want them to be. You could also just assume 255 max and use
0.19347*(V*51)-14.3
Sorry for the cross-talk, V6 looks sweet!
so now i need to find someone in so cal that can tune my car with this. anyone have any tuners in mind around the san gabriel valley area more or less? (gonna go 50/50 if that matters cause i know some tuners like to work with 100 meth only)
Tuning Technologies in Colton, Reese Tuning in San Diego, and RRE in Sante Fe Springs
I have been inundated with the upgrade requests to the HFS-6 on the last few days. I thought you guys can help me with this dilemma.
I have not yet work out the best way to upgrade to HFS-6 from HFS-1 or HFS-1 yet. I have to do this properly and consistantly. My biggest problem would be supporting the next user with a mixture of wirings and harnesses. The easiest way to over come this is by not offering an upgrade path.
At present, the HFS-6 is being offered for $750 at GB until 1st March. At this price, it means you can pass on the HFS-5 at $600-650. I think this is a very nice way to benefit all. This means that you only 100 dollars for the HFS-6 rather an ungrade that may possibly costing more.
Suggestions?
Suggestions?
