Alpine IVA-W502 installed with stock speakers and sub
Old Feb 6, 2009 | 10:30 PM
  #31
Mojito's Avatar
Originally Posted by RaiN907
Do you like the 502? I was thinking about getting it to replace my older pioneer 880.
It's an excellent unit. It will be better if you describe what you don't like about your pionner, then I can tell if Alpine is any better is that department
Old Feb 7, 2009 | 04:19 AM
  #32
RaiN907's Avatar
In my past experience I've had tons of problems with whine, RCA grounding, etc. I found that most alpine units I've had never gave me these problems. I switch HU's like most people switch underwear.
Old Feb 20, 2009 | 04:26 PM
  #33
DetailAddict's Avatar
your dash kit is much better than my metra kit... very nice! did you get a new amp to have the unit work with your sub? i lost the sub in the trunk when I got my F90bt... need new amp, or hack the stock unit (remember seeing a link somewhere).
Old Feb 20, 2009 | 05:38 PM
  #34
HudsonFalcon's Avatar
Yeah I like that dash kit as well, definitely better than spending almost twice as much on JDM. I couldn't find it on Evo-R though.
Old Feb 20, 2009 | 10:03 PM
  #35
Mojito's Avatar
Yes, I got the Alpine PDX-5 amp, which is very compact and works with 2 and 4 ohm impiedance. The stock amp is 2 coils at 1 ohms each, so if you connect them consequently it works. At the moment I'm not very happy with sub performance (sounds weaker than with stock amp). I need to figure out if it's due to Imprint settings, amp gain or incompatibility. I didn't have much time to play wiht it yet as the car is in the garage for tranny swap. Will do it later..
You need to contact them about this kit or order on evoxforums.
Old Feb 21, 2009 | 09:28 AM
  #36
Titaztik's Avatar
I work at a stereo shop here in the states and it's been my personal experience that when tuning the Imprint piece do it WITHOUT the sub hooked up. Then when it's all done tuning hook the sub back up and tune your sub the way YOU WANT. I've ran into the same issue as you that the sub almost doesn't seem like it's there. If you try it the way I just explained then you should be able to get out of your sub what you're looking for. Hope that helps
Adam
Old Feb 21, 2009 | 07:58 PM
  #37
hcope316's Avatar
wow, That looks very good
Old Feb 24, 2009 | 12:21 PM
  #38
Mojito's Avatar
Adam
Thanks, I'll try that.
Old Feb 24, 2009 | 12:30 PM
  #39
Titaztik's Avatar
Not a problem....Let me know how it works out for ya
Old Feb 24, 2009 | 04:26 PM
  #40
wow... i am so lost with this coil/imprint/impiedance talk... what do you mean by 'connect them consequently'? So you saying my F90BT can work with the stock amp and make my sub work?
so with these audio tech talking... help!
Adam
Old Feb 25, 2009 | 02:08 AM
  #41
Mojito's Avatar
No, not with the stock amp. You need to change the amp to make it work. If you want to do that, make sure it works with speakers and sub with impiedance of 2 ohms (like Alpine PDX-5). And ignore the Imprint discussion as it is only relevant for certain Alpine head units.
Old Feb 25, 2009 | 09:22 AM
  #42
gottcha! thanks bro!
Old Feb 26, 2009 | 04:48 AM
  #43
strife's Avatar
Did you mount the PDX-5 under the drivers seat in the stock amp location? If so how did it fit compared to the stock one.
Old Feb 26, 2009 | 04:56 AM
  #44
Mojito's Avatar
Yes, PDX-5 fits under the driver's seat just fine.
Old Mar 3, 2009 | 04:29 PM
  #45
EmperorX's Avatar
Sorry im not good with audio stuff...So with a 5 channel amp 2 channels go to the front speakers, 2 to the rears and one for the sub? waht about the tweeters they use crossovers?
