Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Jul 18, 2009, 08:28 AM
recompile's Avatar
I thought I'd give this patch it's own thread, and organize it nicely. Thank you acamus and mrfred for your work on this.
Disclaimer: This patch is for educational and testing purposes only, and not meant for use on public roads. Be aware that applying this patch on a vehicle that is intended to be inspected by the DMV could be illegal and/or arouse suspicision, especially since this patch can allow you to set the heated catalyst, secondary air monitor or a/c moniter to available/pass even though the car doesn't have it.
Video Tutorial: http://offsite.rallyevo.com/Videos/2...cuflash_06.wmv
This is the patch that will set all inspection tests to "Pass". Acamus has dedicated this patch to Tephra, who could use your donation support. If you enjoy the educational benefit of this patch, please donate.
Originally Posted by tephra
Lastly I have been accepting donations for my work, if you like it or get good use out of it please feel free to paypal whatever you can afford to donations@globalshare.net
Cheers
D.
88590015
PHP Code:
    <table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="3a90c" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="3a922" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="3a928" type="2D" level="1" scaling="Hex16">
table type="Static Y Axis" elements="2">
data>3A928</data>
data>3A92A</data>
table>
table
@3a928 DA66 -> EAFF
@3A92A 6AA1 -> 6AA7
from 4019 to E000
from 6AA1 to EAFF
PHP Code:
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="3a923" type="2D" level="2" scaling="blobbits">
table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8">
data>EGR system</data>
data>Oxygen heater sensor</data>
data>Oxygen sensor</data>
data>A/C system refrigerant</data>
data>Secondary air system</data>
data>Evaporative system</data>
data>Heated catalyst</data>
data>Catalyst</data>
table>
table>
table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="3a929" type="2D" level="2" scaling="blobbits">
table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8">
table>
table
96530006
PHP Code:
    <table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="34C4E" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="34CCE" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="34CD4" type="2D" level="1" scaling="Hex16">
data>34CD4</data>
data>34CD6</data>
table>
table
@34CD4 DA57 -> EAFF
@34CD6 6AA1 -> 6AA7
from 4019 to E000
from 6AA1 to EAFF
PHP Code:
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="34CCF" type="2D" level="2" scaling="blobbits">
table>
table>
table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="34CD5" type="2D" level="2" scaling="blobbits">
table>
table
94170015
PHP Code:
    <table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="36872" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="36888" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="3688E" type="2D" level="1" scaling="Hex16">
data>3688E</data>
data>36890</data>
table>
table
@3688E DA2A -> EAFF
@36890 6AA1 -> 6AA7
@36872 4019 -> E000
@36888 6AA1 -> EAFF
PHP Code:
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="36889" type="2D" level="2" scaling="blobbits">
table>
table>
table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="3688F" type="2D" level="2" scaling="blobbits">
table>
table
96940011
PHP Code:
    <table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="39E24" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="39E4E" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="39E54" type="2D" level="1" scaling="Hex16">
data>39E54</data>
data>39E56</data>
table>
table
@39E54 DA66 -> EAFF
@39E56 6AA1 -> 6AA7
@39E24 4019 -> E000
@39E4E 6AA1 -> EAFF
PHP Code:
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="39E4F" type="2D" level="2" scaling="blobbits">
table>
table>
table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="39E55" type="2D" level="2" scaling="blobbits">
table>
table
94170008
PHP Code:
    <table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="3677a" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="36790" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="36796" type="2D" level="1" scaling="Hex16">
data>36796 </data>
data>36798</data>
table>
table
@36796 DA2A -> EAFF
@36798 6AA1 -> 6AA7
from 4019 to E000
from 6AA1 to EAFF
PHP Code:
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="36791" type="2D" level="2" scaling="blobbits">
table>
table>
table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="36797" type="2D" level="2" scaling="blobbits">
table>
table
MR Turco update - 4/29/10
99860002
PHP Code:
    <table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="2f620" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="2f666" type="1D" level="1" scaling="Hex16"/>
table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="2f66c" type="2D" level="1" scaling="Hex16">
data>2F66C</data>
data>2F66E</data>
table>
table
@2F66C DA51 -> EAFF
@2F66E 6AA1 -> 6AA7
from 4019 to E000
from 6AA1 to EAFF
PHP Code:
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="2f667" type="2D" level="2" scaling="blobbits">
table>
table>
table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="2f66d" type="2D" level="2" scaling="blobbits">
table>
table
Old Jul 18, 2009, 10:49 AM
inco9nito99's Avatar
Great work Christian, thanks for making it public and spending time sharing the videos .
Old Jul 18, 2009, 11:09 AM
ohhgyeahfasho's Avatar
mind me asking what is the main purpose of this patch? is this for smog/state ref? :P
Old Jul 18, 2009, 11:26 AM
LostSolVTEC's Avatar
Amazing work everyone that was involved. Will this be something I can add on even after changing the bits to remove my EGR/EVAP/FPR?
Old Jul 18, 2009, 11:52 AM
acamus's Avatar
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
now we need another for heater itself
recompile, I may guide you if you need some help.
Do I smell STICKY here?
Old Jul 18, 2009, 12:01 PM
tripperfx3's Avatar
Will this work for an VIII? Also I have the rear O2 delete mod and of course with an VIII it wont let me pass emissions. Do I need to remove that?
Old Jul 18, 2009, 12:38 PM
l2r99gst's Avatar
I've been using this for quite a while now on 96530006 and can verify that it passes OBD-II emmissions testing.
Actually, it was pretty funny to see the OBD readiness monitors as passed for items not even on my car.
Old Jul 18, 2009, 12:57 PM
PeteyTurbo's Avatar
I think I can speak for everyone when I say "THANK YOU" to all involved
Old Jul 18, 2009, 01:09 PM
draconx's Avatar
this is awesome!!. lol. thanks man.
Old Jul 18, 2009, 01:58 PM
EvolvedGTI's Avatar
Yes, thank you VERY much!
Old Jul 18, 2009, 01:59 PM
Asmodeus6's Avatar
Absolutely. Greatly appreciate mrfred, acamus' work, and now your tidying up recompile. Patches like these let me rip all the garbage off the car I can't stand.
We are all VERY thankful for your help.
Old Jul 18, 2009, 03:59 PM
4kinboost's Avatar
+1,00000000000000000000000000000000000000000000000 00000
Old Jul 18, 2009, 05:20 PM
KleenWhiteMR's Avatar
i tried doing this, step by step as per the video link, and it was easy untill i hit a problem. when im in notepad++ after ive cut and pasted the tables, i go to save and it tells me "save failed" please check if file is open in other programs or something like that. at the time i didnt even have any other programs running. any help would be greatly appriciated.
Old Jul 18, 2009, 06:04 PM
Evoryder's Avatar
just use regular notepad, and make sure you have the patch entered properly. Also ecu flash should be closed.
Old Jul 18, 2009, 09:37 PM
MR. EVO MR's Avatar
are you adding more roms?
i need 94170008
Quick Reply: Patch: Force OBD Inspection Pass (acamus, mrfred)
