stock mas limit finally found?
Old Sep 11, 2009 | 04:10 PM
  #76
RoadSpike's Avatar
Well posting up my copy of speed density with all mods on e85.
I'll post up a copy with boost control added later right now the scalings are off and its not working like expected.
The full rom is posted along with the xml files so you can do a direct copy if you so please. I used 7zip to compress the rom enough so you'll need that or winrar to open up the file.
EDIT:
Updated the SD patched rom i have
File Type: zip
Old Sep 11, 2009 | 08:41 PM
  #77
whitey4d's Avatar
Is that ROM set up for the 5 bar MAP? If not what is it set up for? Thanks
Old Sep 11, 2009 | 10:32 PM
  #78
RoadSpike's Avatar
yep 5 bar 1200cc injectors basically whats in my sig.
Old Sep 11, 2009 | 11:03 PM
  #79
whitey4d's Avatar
Awesome Thanks alot man. It might be a couple of weeks before I can give it a shot but I plan on it before it gets could here.
Old Sep 12, 2009 | 12:05 AM
  #80
whitey4d's Avatar
deleted. Answered my own Qs with a couple hours of reading.
Old Sep 16, 2009 | 08:54 AM
  #81
RoadSpike's Avatar
I've noticed now that the temperature has dropped a bit below 50F that the cold start on this rom was a bit screwed up. I did a test by rescaling the rom with 0-60 load back to normal so I'm going to post that one up soon. Seems there are a couple tables that really need the 0-60load columns to remain the same for cold start driving purposes.
Old Sep 16, 2009 | 10:06 AM
  #82
Appauldd's Avatar
OHHHH I am so excited now. You may finlly find the cure to the cold start idle issues. You Sir, are amongst the Gods.
Old Sep 16, 2009 | 10:44 AM
  #83
Jack_of_Trades's Avatar
Its always best to keep the 0-60 load and 0-3500 RPM range as the stock scaling for driveability.
Old Sep 16, 2009 | 11:37 AM
  #84
RoadSpike's Avatar
Definitely agreed i had originally scaled it 0,40 and so on thinking the 10-30 loads were redundant. However now it seems they not only effect idle but I've found that cold starting and cold running take off from a stop are much improved.
Just like MrFred I've found i had to add some decay time to the cold start to ensure it doesn't drop lean until the o2 sensor kicks on.
Old Sep 16, 2009 | 11:49 AM
  #85
l2r99gst's Avatar
When I was running SD, I never had any cold start issues that I remember and still don't have any with my new 1250s, but I'm not on SD anymore. I do have all stock scaling for now as well.
I'm curious about your 'dropping lean' comment, though. You were going lean at idle? If your injector scaling and latency is set correctly and your two VE tables are set correctly, the idle should be good.
Old Sep 16, 2009 | 12:03 PM
  #86
l2r99gst's Avatar
On second thought, you are probably talking about the atomization difficulties of E85 at lower temperatures, so the need for more fueling for a longer time, until things warm up.
Old Sep 16, 2009 | 12:04 PM
  #87
RoadSpike's Avatar
Well I run E85 so it may just be a product of that but I've noticed when the air temp is below 50F it would start fine then sorta stumble lean then correct itself to running right.
Seems most of the issues were simply how the load in the low range was scaled.
Old Sep 17, 2009 | 09:55 AM
  #88
Mellon Racing's Avatar
why did you get away from SD?
Old Sep 17, 2009 | 10:01 AM
  #89
l2r99gst's Avatar
There was a weird IPW oscillation that I was experiencing only in a very specific RPM and map range.
Here is page 4 of the thread where I was testing and found the issue. I have posted and discussed it from that page on, but never found the exact cause.
All in all, it's not that big of a deal, but I would rather have it solved before I run SD full time, since this is my only car. I may still switch over anyway, since I have a 4" intake pipe and filter that I have been waiting to put on. But, I wanted someone to look over the code again to see if they see something that may be causing it.
Old Sep 17, 2009 | 10:05 AM
  #90
can you elaborate?
