Tephra v7 and Load?
Old Mar 10, 2010 | 02:41 PM
Seijuro's Avatar
Tephra v7 and Load?
So what's the deal with the Tephra rom and load? It appears to be configured to use the 1 Byte Load factor only (request 41).
What about the compensated loads? I've read that based on the Intake Air Temperature sensors reading, timing may be based on load with baro compensation, or load with baro and temp compensation.
The Tephra v7 thread states this;
Preconfigured MUT Requests
MUT00+MUT01 = 2byte airflow (ie MrFreds mod in g/s or lb/min)
MUT02+MUT03 = 2byte airflow (ie MAFHz)
MUT40 = 1byte gear
MUT41 = 1byte load
MUT42+MUT43 = 2byte SPEED/RPM ratio (to get your gear ratios correct - if you need to)
2byte load AND 2byte RPM are no longer included and IMHO not needed!
Why is 2byte load no longer needed? According to the following, the new 1byte load is still RAW Load.
Isn't the ECU almost always using a temperature and/or baro compensated load?
Addresses
MUT Table
36200
There are 4 different 2-byte Load choices each with different correction factors.
2-byte LOAD_Raw (no temp compensation)
MUT00 = 8984
MUT01 = 8985
2-byte LOAD_Temp_Compensated
MUT00 = 8986
MUT01 = 8987
2-byte LOAD_Baro_Compensated
MUT00 = 8988
MUT01 = 8989
2-byte LOAD_Temp_and_Baro_Compensated
MUT00 = 898A
MUT01 = 898B
Load correction note: The ECU uses the following logic to find the lookup info it needs:
Fuel maps will either use Load_Raw OR LOAD_Temp_and_Baro_Compensated depending on an certain conditions
Ignition Maps will either use LOAD_Baro_Compensated OR LOAD_Temp_and_Baro_Compensated depending on the MAF IAT. (Thanks to Tephra for this info).
It is typically best to use the 2-byte LOAD_Temp_and_Baro_Compensated for tuning, while taking into account the lookup factors mentioned above for both Fuel and Ignition Timing. This will allow the tuner to accurately tune ignition timing while being able to compensate for the lookup logic for fueling. LOAD_Raw is typically 10-20 points higher than LOAD_Temp_and_Baro_Compensated at peak boost. You must take this into account when tuning using the 2-byte loads. With the advent of Tehpra's 1byte load(using a Tephra Mod ROM), you can use 1byte load(which is actually LOAD_Raw) to log LOAD_Raw. You can setup your 2byte load to be LOAD_Temp_and_Baro_Compensated, this will allow the tuner to see both compensated load and LOAD_Raw. Ultimatly, how you decide to set-up your 2-byte load and the methods you use to tune are up to you.
Other Addresses:
2-byte RPM
MUT02 = 8962
MUT03 = 8963
2-byte AirFlow
MUT04 = 89E2
MUT05 = 89E3
Retrieved from "http://evoecu.logic.net/wiki/96530006"
Old Mar 10, 2010 | 04:08 PM
l2r99gst's Avatar
Your answer is already in what you quoted and read. Tephra'a 1byte load is the uncompensated, raw load.
If you want to log any of the other loads, then you have to setup your logging program and/or MUT table to do so.
Old Mar 10, 2010 | 04:12 PM
Seijuro's Avatar
I realized I wasn't very clear in my question, I edited the post to clarify what I was getting at. Right in what basically serves as the documentation for the Tephra v7 ROM, it states that 2byte load was not set up because it's considered not necessary.
What's not necessary about it is what I don't understand.
EDIT: I guess to try and answer my own question, the Tephra v7 post is trying to say that 2byte RAW Load is not necessary because it's redundant.
But, I think in the real world, you still need your baro and temp compensated loads.
Is the same process of dividing down the load value in the ECU, and then multiplying it back out in the logger applied for these compensated loads somewhere as well and I'm just not seeing it?
Old Mar 10, 2010 | 04:27 PM
l2r99gst's Avatar
Yep, you got it.
Tephra only did the 1byte mod to the 2byte raw load. So, if you want to log baro+temp comp load, then you need to do it the old fashioned way and log the two variables.
Old Mar 20, 2010 | 11:53 AM
BillSpec's Avatar
tephra
Apr 22, 2026 11:03 AM
chmodlf
Aug 31, 2018 01:38 PM
Jack_of_Trades
May 29, 2018 07:05 AM
neuralcj
Jan 7, 2018 02:50 PM
roni4g63
Nov 14, 2015 11:45 AM
