psi based boost control
Old Jul 19, 2010 | 12:14 AM
tephra's Avatar
Cool psi based boost control
Hi Guys,
1) A BIG thanks to MrFred for working this out on CT9A, this is basically a rip-off of that
2) This is really only good for 3port setup's
3) The scaling is setup for the STOCK 3bar sensor - if you have a different sensor in there you will NEED to modify the scalings
4) Sharing is caring! Let me know if these definitions work for other ROMID's (I am sure some do)
53040010:
Code:
<scaling name="Throttle_Main - Stored Minimum Throttle %" units="%" toexpr="(x+(90/4))*100/255" frexpr="x*255/100-(90/4)" format="%.1f" min="0" max="100" inc="2" storagetype="uint16" endian="big"/>
<scaling name="BoostErrorPsi" units="psi" toexpr="(x-128)*0.19347/4" frexpr="(x*4/0.19347)+128" format="%.1f" min="-6.1" max="6.1" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="OffsetWGDC" units="WGDC Change" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.5" storagetype="uint8" endian="big"/>
<scaling name="psia8" units="psia" toexpr="x*0.19347" frexpr="x/0.19347" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint8" endian="big"/>
<scaling name="psia16" units="psia" toexpr="x*0.19347" frexpr="x/0.19347" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint16" endian="big"/>
<table name="Atmospheric Boost" category="Direct Boost" address="53484" type="1D" scaling="psia16"/>
<table name="Target Boost Error Correction" category="Direct Boost" address="58cd8" type="2D" scaling="OffsetWGDC">
	<table name="Boost Error" address="625f6" type="Y Axis" elements="17" scaling="BoostErrorPsi"/>
</table>
<table name="Boost Target #1A (High Gear Range)" category="Direct Boost" address="58e45" type="3D" swapxy="true" scaling="psia8">
	<table name="Throttle" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %" address="6264e"/>
	<table name="RPM" type="Y Axis" elements="18" scaling="RPM" address="625cc"/>
</table>
<table name="Boost Target #1B (High Gear Range)" category="Direct Boost" address="58eef" type="3D" swapxy="true" scaling="psia8">
</table>
<table name="Boost Target #2 (Low Gear Range)" category="Direct Boost" address="573f5" type="3D" swapxy="true" scaling="psia8">
</table>
<table name="Variable for Boost Control 0xC76C -> 0xC712" category="Direct Boost" address="9e732" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="9e734" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC588 -> 0xC586 (is 0x808586 for logging)" category="Direct Boost" address="9e75a" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address in Load Error Table 0xC588 -> 0xC586" category="Direct Boost" address="625f2" type="1D" scaling="Hex16"/>
52680022:
Code:
<table name="Target Boost Error Correction" category="Direct Boost" address="58cd4" type="2D" scaling="OffsetWGDC">
	<table name="Boost Error" address="625b8" type="Y Axis" elements="17" scaling="BoostErrorPsi"/>
</table>
<table name="Boost Target #1A (High Gear Range)" category="Direct Boost" address="58e41" type="3D" swapxy="true" scaling="psia8">
	<table name="Throttle" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %" address="62610"/>
	<table name="RPM" type="Y Axis" elements="18" scaling="RPM" address="6258e"/>
</table>
<table name="Boost Target #1B (High Gear Range)" category="Direct Boost" address="58eeb" type="3D" swapxy="true" scaling="psia8">
</table>
<table name="Boost Target #2 (Low Gear Range)" category="Direct Boost" address="573f1" type="3D" swapxy="true" scaling="psia8">
</table>
<table name="Variable for Boost Control 0xC774 -> 0xC71A" category="Direct Boost" address="a0cc6" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="a0cc8" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC590 -> 0xC58E (is 0x80858E for logging)" category="Direct Boost" address="a0cee" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address in Load Error Table 0xC590 -> 0xC58E" category="Direct Boost" address="625b4" type="1D" scaling="Hex16"/>
55590007:
Code:
<table name="Target Boost Error Correction" category="Direct Boost" address="58d78" type="2D" scaling="OffsetWGDC">
	<table name="Boost Error" address="62812" type="Y Axis" elements="17" scaling="BoostErrorPsi"/>
</table>
<table name="Boost Target #1A (High Gear Range)" category="Direct Boost" address="58ee5" type="3D" swapxy="true" scaling="psia8">
	<table name="Throttle" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %" address="6286a"/>
	<table name="RPM" type="Y Axis" elements="18" scaling="RPM" address="627e8"/>
</table>
<table name="Boost Target #1B (High Gear Range)" category="Direct Boost" address="58f8f" type="3D" swapxy="true" scaling="psia8">
</table>
<table name="Boost Target #2 (Low Gear Range)" category="Direct Boost" address="57495" type="3D" swapxy="true" scaling="psia8">
</table>
<table name="Variable for Boost Control 0xC78A -> 0xC72E" category="Direct Boost" address="a35ca" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="a35cc" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC5A4 -> 0xC5A2 (is 0x8085A2 for logging)" category="Direct Boost" address="a35f2" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address in Load Error Table 0xC5A4 -> 0xC5A2" category="Direct Boost" address="6280e" type="1D" scaling="Hex16"/>
55570006:
Code:
</table>
</table>
</table>
</table>
<table name="Variable for Boost Control 0xC78A -> 0xC72E" category="Direct Boost" address="a36aa" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="a36ac" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC5A4 -> 0xC5A2 (is 0x8085A2 for logging)" category="Direct Boost" address="a36d2" type="1D" scaling="Hex16"/>
55580006:
Code:
</table>
</table>
</table>
</table>
<table name="Variable for Boost Control 0xC78A -> 0xC72E" category="Direct Boost" address="a36ea" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="a36ec" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC5A4 -> 0xC5A2 (is 0x8085A2 for logging)" category="Direct Boost" address="a3712" type="1D" scaling="Hex16"/>
53050009:
Code:
</table>
</table>
</table>
</table>
<table name="Variable for Boost Control 0xC76C -> 0xC712" category="Direct Boost" address="9e6ca" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="9e6cc" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC588 -> 0xC586 (is 0x808586 for logging)" category="Direct Boost" address="9e6f2" type="1D" scaling="Hex16"/>
52690022
Code:
</table>
</table>
</table>
</table>
<table name="Variable for Boost Control 0xC774 -> 0xC71A" category="Direct Boost" address="a0d06" type="1D" scaling="Hex16"/>
<table name="SHLR->SHLR2 0x5101 -> 0x5102" category="Direct Boost" address="a0d08" type="1D" scaling="Hex16"/>
<table name="Boost Error RAM Address 0xC590 -> 0xC58E (is 0x80858E for logging)" category="Direct Boost" address="a0d2e" type="1D" scaling="Hex16"/>
As always ensure the BEFORE numbers match before saving/flashing
And definitely give me money :P hehe
Old Jul 19, 2010 | 12:15 AM
tephra's Avatar
Oh I forgot:
This works for altmaps - just change the scaling
ie
<table name="Alt Boost Target Engine Load #2 (Low Gear Range)" address="f0517" category="TephraXMOD V1" type="3D" swapxy="true" scaling="Load8">
would become
<table name="Alt Boost Target #2 (Low Gear Range)" address="f0517" category="TephraXMOD V1" type="3D" swapxy="true" scaling="psia8">
I run both sets of tables - but you can rename/delete the old one if you liked
HB Speed's Avatar
test....ing
Old Jul 19, 2010 | 12:22 AM
tephra's Avatar
cheers bigears
some of the more observant people will notice that you can now log boost error - see the xml for the correct memory address... (yes its different depending on ROMID)
Old Jul 19, 2010 | 12:32 AM
GST Motorsports's Avatar
Awesome
Old Jul 19, 2010 | 12:36 AM
Neither work for USDM Ralliart.
- Bryan
Old Jul 19, 2010 | 12:38 AM
tephra's Avatar
ok... give me a couple of mins
Old Jul 19, 2010 | 12:45 AM
tephra's Avatar
55590007 - done
Old Jul 19, 2010 | 08:29 AM
Originally Posted by tephra
55590007 - done
You da man, and you haz paypal.
- Bryan
Old Jul 19, 2010 | 08:47 AM
Golden's Avatar
I tried the scalings for 55590007 for my 55570106 ROM, and all the tables look right, but all the xxxx -> yyyy are not correct. ( except the Boost Error RAM Address in Load Error Table)
Old Jul 19, 2010 | 09:02 AM
tsitalon1's Avatar
Call me a dunce, but I need a little help with this statement.
I know I need to verify the addresses, but against what, how would I verify the address is correct before I flash it?
Sorry for the juvenile question.
Old Jul 19, 2010 | 09:19 AM
saytheb's Avatar
Typically you'll see something like:
0C19 -> FFFF
You want to verify that when you go to edit, the original value is '0C19', if it's not, check back here.
Old Jul 19, 2010 | 09:28 AM
scheides's Avatar
EvoM Moderator
Holy crap, thank you tephra! Nice work!
Now all we need is 100% WGDC under load X....
Old Jul 19, 2010 | 09:35 AM
ViscontiFlash's Avatar
2010 gsr
Old Jul 19, 2010 | 09:52 AM
murlo26's Avatar
Woo, the X is starting to get all the good stuff too now
Now we just need an upgraded MAP sensor scaling
Tephra, I saw a thread about John Bradley saying he just put in a 4 bar MAP sensor and he was able to change global fueling to compensate, is that possible?
