Tephra v7 issue
Old Jul 27, 2010 | 02:23 PM
biggie5252's Avatar
Tephra v7 issue
I've searched and couldn't find this problem. I also don't believe I had it before.
In ecuflash using 88590715 with Recompile mods xml, the Desired ISCV intial step position with AC on and off tables don't show up. If I just use the 88590715 xml they do show up. I tried a complete delete and reinstall of ecuflash and fresh v7 downloads.
Am I missing something?
Thanks.
Old Jul 27, 2010 | 02:54 PM
evo8426's Avatar
mine do not show up either
Old Jul 27, 2010 | 07:25 PM
hediki12's Avatar
it shows up in mines... if your running windows vista or win 7 try this
C:\Users\*you user name*\AppData\Local\VirtualStore\Program Files (x86)\OpenECU
make sure all files and folders are not hidden...
put the xml there n reopen ecuflash. let me know if it works!
Old Jul 27, 2010 | 09:56 PM
biggie5252's Avatar
I'm running 7. The last time I messed with those tables was with xp. I'll give it a shot and see what I come up with. Thanks.
Edit: I don't see a folder named appdata under C:\Users\*you user name*
Old Jul 27, 2010 | 10:04 PM
Lmodel's Avatar
Answer:
Old Jul 27, 2010 | 10:14 PM
biggie5252's Avatar
Ok, how do I unhide folders in 7? I've only had it for a little bit and can't find it. I know how to unhide folders in xp.
nvm found it.
Old Jul 27, 2010 | 10:28 PM
biggie5252's Avatar
Now I don't have an OpenEcu folder under C:\Users\*you user name*\AppData\Local\VirtualStore\Program Files. I don't have the (x86) either. I do have evoscan and scantech. Those are the only folders under progam files.
This is on an hp mini 1030nr with windows 7 home premium if it matters.
fp-green-95tsi
Apr 28, 2026 03:47 AM
ant_turbo
Apr 10, 2015 08:16 PM
killerpenguin21
Mar 31, 2014 06:42 PM
el.guerrero
Nov 3, 2012 04:25 AM
nightwalker
Apr 16, 2012 07:10 AM
