Interesting remap in JDM car
Old Jul 30, 2010 | 06:05 PM
Benja's Avatar
Sorry mate.
File Type: zip
Old Jul 30, 2010 | 06:08 PM
Benja's Avatar
And original one.
File Type: zip
Old Jul 30, 2010 | 06:10 PM
Benja's Avatar
Yeah dont mind at all if you can whip up one for me for the interim.
I do want to sort it all out myself eventually, but haven't got a front pipe with permanent LC-1 installed etc. so just using a tail pipe wideband with decat and logging A/F's seperately.
Car is running 98RON, so ~92-93MON for you guys.
Old Jul 30, 2010 | 06:52 PM
tscompusa2's Avatar
a tailpipe wideband.. ok so its gonna read alitle leaner in logs then what it actually is. so about 11.8-12 afr we want
Old Jul 30, 2010 | 06:57 PM
tscompusa2's Avatar
can i get a 3rd gear pull of the new rom with the better timing and fuel?
Old Jul 30, 2010 | 07:01 PM
Benja's Avatar
Yeah no dramas! i'll report back in an hour or so.
It shouldn't be too much leaner as I knocked the cat out yesterday as well.
Old Jul 30, 2010 | 07:06 PM
tscompusa2's Avatar
sounds good!
Old Jul 30, 2010 | 10:40 PM
Benja's Avatar
Ok back again, had to do a few other things, and threw a new set of plugs in as well. (BPR7ES)
So at the tailpipe, i'm getting 12.5-12.4 at high 3k dropping down to 12.1 top end. (stock dump/front/decat/cat-back)
Idle is sitting stable at 17.1-17.3, cruise is mid-high 14's too low 15's at times.
First log is a 3rd gear pull, unsure if i'm sposed to be logging so much as well.
Mines a JDM car, but looks like the JDMMAP part only reads to 1bar boost (33psi), guessing i'll need a JDM E9 part to log it properly yeah?
Oh and how is the AFRMap calculated? As its showing a/f ratio's like a wideband!? Is that calculated off the narrowband voltage?
Car seemed nice and strong, idles much better on new plugs too!
Was slow flashing CEL here and there, assuming this is the Tephra knock warning? But after checkign the logs, seemed to be only hitting high knock when touching the rev limiter.
Old Jul 30, 2010 | 10:41 PM
Benja's Avatar
And a log of a 2nd/3rd pull, again the only worrying knock is on the limiter, which i'm assuming is probably phantom knock yeah?
Old Jul 30, 2010 | 10:55 PM
hediki12's Avatar
Originally Posted by Benja
Yep, poor car.
Hopefully it hasn't had too much damage done to it, i'd say the only reason why it hasnt' popped again is due to the forged pistons standing up to the carnage a little longer.
No idea who tuned it Ziad, BUT its been looked after by Meek 12m ago, I doubt they'd throw these maps on there surely though.
Attached the one and only log before reflashing.
holy knocksum gods! lol. i dont think this a pump (93 oct) map not the lease bit close...
Old Jul 30, 2010 | 11:32 PM
Benja's Avatar
True, but its even getting up there in the aggressive stakes for a Meth or 85 map too!
Old Jul 30, 2010 | 11:45 PM
D-VO's Avatar
That's correct! I wouldn't worry about the knock on the rev limiter. I'm suprised that the logs look so good with that much timing! How do the knock control settings look? I'm wondering if they may be set too high.
Old Jul 30, 2010 | 11:48 PM
Benja's Avatar
Yeah I seem to be running 6-8 deg at peak torque now, everyone else 2-4
Old Jul 31, 2010 | 12:15 AM
D-VO's Avatar
What about the knock control maps? I'm a bit worried for you.
Old Jul 31, 2010 | 12:35 AM
Benja's Avatar
Hmmm....I can't see that in my definition...can you?
