High knock count on idle revving *log inside*
Old Apr 2, 2011 | 01:10 PM
stunt2's Avatar
Exclamation High knock count on idle revving *log inside*
Any suggestions why can it be such high numbers ?
Old Apr 2, 2011 | 01:28 PM
Guerillah's Avatar
Is your downpipe rattling against the transfer case?
Old Apr 2, 2011 | 01:37 PM
stunt2's Avatar
dunno, can't hear any wierd noises inside the car
Old Apr 2, 2011 | 02:32 PM
JohnBradley's Avatar
The normal non catastrophic list-
Lifters arent bled right
exhaust rattles
balance shaft delete
wrong plugs
bad knock sensor
Catastrophic-
Rod bearings
Main bearings (can check this vs oil pressure)
Piston slap
Log knock voltage as well.
aaron
Old Apr 2, 2011 | 03:35 PM
SEEnoEVO's Avatar
I was getting strange numbers when my knock sensor wasn't connected. May want to check that.
Old Apr 3, 2011 | 12:25 PM
211Ratsbud's Avatar
I have found through my own tuning, that map smoothing is quite important for idle revving. Its one of hte more tedious parts to tune IMHO and I still dont have it right. Depending how hard you press the pedal, and how hard you lift.. just my 2 cents
Old Apr 7, 2011 | 10:35 AM
soon2bEVOIX's Avatar
Is this a common problem. I am having the same issue.....
Old Apr 7, 2011 | 12:41 PM
andrewzaragoza's Avatar
^ shouldn't happen if you bought a downpipe that was designed for acd equipped cars.
Old Apr 7, 2011 | 12:44 PM
goodhart's Avatar
My knock light comes on when I hit the two-step, but not when only revving to 3700ish rpm
Old Apr 7, 2011 | 12:57 PM
to fix that smoothen the cells around the rev limit area.
Old Apr 7, 2011 | 01:44 PM
Yeah that's prob my problem. I bought the DP from a buddy who sells Evo's and puts them back stock. So I have no clue what brand of if it's for ACD equipped cars.
Old Apr 7, 2011 | 02:29 PM
if its barely touching i would suggest just flattening the dp a bit.
MaRgE
Mar 1, 2015 08:48 AM
voidhawk
13
Jul 12, 2013 09:07 PM
azevo9
For Sale - Wheels / Tires
10
Nov 27, 2008 08:03 PM
azevo9
Nov 20, 2008 02:19 PM
