I need some info!
Old May 5, 2004 | 05:03 PM
Surfer_Sandman's Avatar
Question I need some info!
A couple of things I need. I need these numbers off of a ES lancer
What is our Normal oil Pressure?
" " Spark Plug type and gap?
" " firing order and ignition timing?
Last but not least what is our Valve clearance?
Thanks guys and gals
Old May 5, 2004 | 07:29 PM
digdat's Avatar
the spark plug gap can be found on the sticker under the hood. i'd go look at mine but i'm still at work. I think its .42 but not entirely sure.
the under-da-hood sticker may have more of that information as well ...
sorry I couldn't help more!
Old May 5, 2004 | 10:03 PM
RollerPyro's Avatar
I might be able to let you know tomorrow. My school has AllData, I'll try to look it up.
Old May 5, 2004 | 10:21 PM
cool thanks, I need it for a school project
Old May 6, 2004 | 12:04 AM
eldanoloco's Avatar
Spark plug gap and firing order should be in your owners manual, valve clearance can probably be found in the factory service manual and ignition might be found there or the factory tech manual. Oil pressure is a tough one. The only way I could think of getting a real answer, install a oil pressure gauge.
Old May 7, 2004 | 08:22 AM
RollerPyro's Avatar
PLUG GAP: 1.0 -1.1 mm (0.39 - .043 in)
PLUG TYPE: DENSO - K16PR-U11
CHAMPION - RC10YC4
NGK - BPT5E-11
Old May 7, 2004 | 08:24 AM
RollerPyro's Avatar
IGNITION TIMING: 5 deg BTDC +/- 3 deg
Old May 7, 2004 | 08:32 AM
RollerPyro's Avatar
Oil pressure at idle Standard value 29 kPa or more
at 3,500 r/min Standard value 294 - 686 kPa
Old May 7, 2004 | 08:33 AM
RollerPyro's Avatar
Couldn't find anything about valve clearance or firing order.
Old May 8, 2004 | 08:29 AM
Blacksheepdj's Avatar
AllData rules...
Firing order = 1-3-4-2
Old May 8, 2004 | 08:33 AM
And again...
Valve clearance Standard values
Intake 0.02 - 0.05 mm
Exhaust 0.04 - 0.06 mm
Limit Intake 0.10 mm
Limit Exhaust 0.15 mm
Old Feb 8, 2006 | 11:59 AM
blaze_125's Avatar
CHAMPION - RC10YC4
NGK - BPT5E-11
I was looking for Spark plug # so I figured I'd bump this thread for somebody else who might be looking.
Old Feb 8, 2006 | 12:17 PM
freakishpower's Avatar
1342 i believe
Old Feb 8, 2006 | 01:36 PM
gregivq's Avatar
I bump this thread to make this a sticky or change the title so it's easier to find.
Old Feb 9, 2006 | 06:07 AM
blaze_125's Avatar
I feel the plug info is wrong though... I went to the store yesterday and couldn't find any NGK with that park number. The plugs I pulled out didn't show that number either...
