Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
265/35 w/ H&R lowering spring??
Old Jun 11, 2011 | 07:23 PM
jkc213's Avatar
are they gonna rub w/ 18x9.5+22 wheels?? planning to get this set-up but dont wanna roll my fenders.... THANKS...
Old Jun 11, 2011 | 07:28 PM
ugakirk's Avatar
Probably.. I've seen guys that had to roll fenders on swifts with 265s and h&r's are lower than those. You would have to go with 255's and maybe a little bit of camper would be my guess. My H&R's are quite low but I love them
Old Jun 11, 2011 | 08:45 PM
jkc213's Avatar
R u on stock wheels?
Old Jun 11, 2011 | 09:10 PM
raytrix's Avatar
as long as you have -1.5 degree camber in the rear you should be fine.
Old Jun 12, 2011 | 01:06 AM
jkc213's Avatar
[quote=raytrix;9385938]as long as you have -1.5 degree camber in the rear you should be fine.[/quote
with that camber, are they gonna wear out my tire faster??
whats the ideal alignment spec. for this set-up?? thanks..
Old Jun 12, 2011 | 07:46 AM
raytrix's Avatar
[QUOTE=jkc213;9386122]
not really, factory front camber on the car is set at -1 degree already. putting the rear close to that or slightly above will be the same as the front. Anything in the -3 and up territory will start seeing some uneven wear by a lot. When I had 18x10 +18 on 265/35 I had to roll the rear and run -2.8 camber all around . Now my 19x10.5 +25 with 5mm spacer front I am doing -2.5 front -2 rear. Mind you it's suggested that you roll the fender if you ever do run something close or lower than 18x9.5 +22 . 18x9.5 +22 on a 265/35 is borderline of a fender roll all based on if you have a car with 4 people in it and lowered more than 1.5 inches. 2 people in the car at that height you are fine without a roll. I would just roll it for the hell of it, it's only around $150 for a pair to be done in most body shop with a roller.
Old Jun 12, 2011 | 07:15 PM
jkc213's Avatar
so I pulled the trigger... They did not rub... I'll post pics later.
Old Jun 12, 2011 | 08:04 PM
wrxnevox's Avatar
i want to see the pictures!
Old Jun 12, 2011 | 08:05 PM
Frankiago's Avatar
Here's my take on it:
I have 18x9.5 +15 wrapped in 265/35 Dunlop Star Specs. Lowered on Swift Sports, they rubbed like a sum'bish in the rear and were perfectly fine up front.
They WILL hit the heights required for rub in the rears, it's just a question on whether or not the rubber is tucked inside the fender. I might have just barely rubbed on +22, but the Star Specs are a wider tire than most others, so unless you're on Star Specs, your 265's have a more narrow contact patch.
Alignment of -1.2 camber rear did not help, but -2 or -2.5 probably would have. Not willing to go that far for the sake of not rubbing, so I had the rears rolled. Have not had a problem since then with the same alignment specs.
So your success is a combination of narrow 265's and that extra 7mm of offset tucked in versus +15's I ran.
Notice on the last pic the tire actually grabbed the fender and pulled it down! This was after a road trip from Chicago to Michigan to run laps at Gingerman Raceway.
Old Jun 13, 2011 | 12:21 AM
jkc213's Avatar
here's the pic!!! the tire's is 265/35/18 w/ H&R spring...
thanks evryone for the help..
Attached Thumbnails 265/35 w/ H&R lowering spring??-dsc03376.jpg   265/35 w/ H&R lowering spring??-dsc03377.jpg
Old Jun 13, 2011 | 06:38 AM
Evo Tengoku's Avatar
Looks good. What kind of tires are they?
Old Jun 13, 2011 | 11:12 PM
jkc213's Avatar
thanks.. its BF goodrich g-force
Old May 5, 2012 | 07:06 AM
Inprogress's Avatar
Anymore pics with the H&R springs installed?
Old May 5, 2012 | 07:16 AM
Iowa999's Avatar
Maybe this comment belongs in Site Feedback, but anyone who posts in a "will these tires rub?" thread without specifying offset should probably have their posts deleted....
This is not a good thread in which to be looking for really useful information. Check for a thread where offset is consistently provided by posters.
edit: apologies to the two posters above who did provide offset; this little rant was aimed at the other people
Old May 5, 2012 | 12:05 PM
xmrevo86's Avatar
great look!
