Sponsored by:
Sponsored by: CARiD
Shifter wiggles after installed short shifter and bushings
Old Nov 9, 2011 | 10:19 AM
  #31
NHEvo24's Avatar
Something is absolutely wrong. Open up the hood and check the bushings and shifter arms while someone wiggles it around. If you don't see play in the cables on the transmission, it's in the console under the shifter.
Old Nov 12, 2011 | 05:00 PM
  #32
RiG's Avatar
RiG
Originally Posted by nessus
Thank you all for all the feedbacks and helps. Last weekend I finally nailed down what the problem was: after carefully going through the install manual again, I discovered the "white nylon" cap, as described in the manual is gone from my transmission arm. As I dont recall seeing this white piece cap at all during my installation, it must have dropped when it pulled the transmission arm out. This little piece of nylon or plastic holds the tightness of the shifter in the left-right direction.
I found something similar to replace this missing part for now, not perfect nor ideal, but it's close to stock as far as the wiggling goes.
Shouldnt have rushed it!!
Thank you everyone again for all the helps.
Sorry to bring this thread back from the dead, but did you ever find the part number for this piece? on the EVO X forum, someone said they ordered this part from the dealer but didnt list the P/N and Im not a member over there. I went to install my bushings and that piece was gone! I dont know if I lost it pulling it out or if it was a quality control issue but mine is not there. Thanks
Mike
Old Nov 13, 2011 | 11:21 PM
  #33
superluz's Avatar
Hi Mike
I have exactly the same problems as you have.
I’ve just ordered a modified version of the plastic part. (They guaranteed me that will be 100% compatible with Evo X, and will improve shift quality )
See the pictures.
It’s cost 15gbp.
I will install it on the weekend, and let you know the results
For ordering the parts:
ross@rosssport.com
Attached Thumbnails Shifter wiggles after installed short shifter and bushings-dsc_0574.jpg   Shifter wiggles after installed short shifter and bushings-dsc_0575.jpg   Shifter wiggles after installed short shifter and bushings-dsc_0580.jpg
Old Nov 14, 2011 | 01:09 AM
  #34
nessus's Avatar
Originally Posted by superluz
Hi Mike
See the pictures.
It’s cost 15gbp.
ross@rosssport.com
That doesn't look anything close to the original white nylon cap. I can't really see how it fits to the shift arm. But please us posted once you installed it. Thanks!
To answer other members' question: no, I haven't ordered or found a 100% replacement for it yet. As I forgot to mention in my last reply, I actually used a tire pressure valve cap as the replacement. Not as good as stock obviously, but it's better than nothing.
My longer term solution would be to dissemble the shifting cable again, get dimension measured and go buy some thick nylon and hard plastic cables, then cut it up myself. It shouldn't be too difficult to do, but I just haven't got the time and patient to do it yet.
Old Nov 14, 2011 | 01:56 AM
  #35
superluz's Avatar
From this picture and the one I've posted before they look quite similar to me...but I may be wrong.
Attached Thumbnails Shifter wiggles after installed short shifter and bushings-3.jpg
Old Nov 14, 2011 | 07:09 AM
  #36
RiG's Avatar
RiG
At least I now know what it looks like! haha. superluz, where did you find that piece at? I wouldnt mind trying one out. I used a piece of silicone hose cut to length and it works ok but I want to get this fixed ASAP.
Old Nov 14, 2011 | 07:33 AM
  #37
superluz's Avatar
We have to thanks Mr.Google ;-)
You can order it at:
ross@rosssport.com
It cost 15 GBP.
I will install it on Sunday and then report back..
Finger crossed...
Old Nov 14, 2011 | 11:02 AM
  #38
user 629782012's Avatar
I installed TWM short shifter + under hood shifter cable bushing over a week ago, the shifter really works except now in each gear the shifter wiggles by quite much, definitely more than when it was stock. By wiggling, I mean if I grab the shifter knob doing a left-right motion while in any gear, the shifter wiggles quite bit, gives you a very loose feeling.
I notice the 1st, 2nd, 5th and reverse gears wiggle the most since they are on the outside. 1st and 2nd wiggles toward left, and 5th and reverse toward right.
The wiggling only happens on the left-right direction.
I have searched the forum and google, no one has mentioned anything like this.
something sounds like it wasn't installed right... TWM is know for ZERO Wiggle! after you install it.. with proper torque on all the scews and bolts it will be secure. Ive had 3 of this shifters since 2006 and all performed flawlessly!
Old Nov 15, 2011 | 12:29 AM
  #39
nessus's Avatar
ross@rosssport.com
It cost 15 GBP.
Finger crossed...
It kinda make sense seeing those pics now. Keep us posted. Thanks!
Old Nov 15, 2011 | 09:32 AM
  #40
evokerfes's Avatar
The dealer doesn't carry the white nylon cap?
Old Nov 21, 2011 | 11:01 PM
  #41
superluz's Avatar
Thumbs up Yes it worked!!
Yes it worked!!
I installed the upgraded cap yesterday....wow what a nice feeling!!
100% Happy!
Old Nov 22, 2011 | 06:51 AM
  #42
RiG's Avatar
RiG
The dealer does have the white cap! I just went on Friday and ordered it. It is supossed to show up today. I will post up the part number when I get home.
Old Nov 23, 2011 | 12:10 AM
  #43
nessus's Avatar
Yeah, please do post the part number when you get a chance. Thanks!
Old Nov 23, 2011 | 02:56 PM
  #44
RiG's Avatar
RiG
Alright I got the part number and the name for the white plastic piece. haha.
Manual Transmission Shift Linkage Shoe P/N MD771824.
It cost me $5.67 plus tax. So now everyone can order it online if they lose it. Good luck
Old Nov 25, 2011 | 03:44 PM
  #45
No_Skillz's Avatar
^^ OP needs to update first post with this info... you spent almost a full year trying to fix this, props to that.
