AEM EMS Get tuning help for your AEM EMS system.
Base map for hks 3037 turbo kit??
Old Sep 24, 2007 | 01:35 AM
omtorlak's Avatar
Hi,
Does anyone of you guys have this map? I run my evo8 with 3.5 bar map sensor
Old Sep 25, 2007 | 07:57 AM
8URVTEC's Avatar
Need more info! Cams, Turbo AR, 2.3, 2.1 or 2.0? I might have what you need, but I need more information on your car.
Old Sep 30, 2007 | 12:15 PM
omtorlak's Avatar
Thanks for the reply,
Most of the problems are solved..
I purchased the AEM pro, and started tuning it with the MAP sensor. Things are fine but I have problem with the knock sensor. My knock sensor does incredible things that I cant understand? For example in 200 load with a 9 degree timing in 7000 rpm (other timings are also conservative), it notices knock and pulls timing and it can happen in various rpm's. You may say that my engine is knocking. But even if I pull timing to 2 degrees it notices knock tooo??? I tried to calibrate the knock sensor to 3 volts max, but no change. I tested my compression ratios and they're around 130 psi. Have you experienced alike problem? I'm hungry to tune my car..
Please helpp...
Old Sep 30, 2007 | 04:44 PM
Spaceball 1's Avatar
130 psi compression seems very low...
Tuning it with the map sensor?
post your calibration file and we might be able to help you.
Old Sep 30, 2007 | 05:52 PM
alpha's Avatar
Like Spaceball said. Post your calibration and some logs
Old Oct 2, 2007 | 11:03 PM
8URVTEC's Avatar
Sometimes there is a noise that the knock sensor picks up! It is more defined as motor noise according to two shops I spoke to about the same problem. My timing was turned to 2 degrees also and the AEM still recognized it as knock. My tuner has tried numerous times to get this taken care of, but to no avail.
babaz7
May 27, 2021 11:35 PM
Raceghost
Nov 16, 2016 08:53 PM
db1
May 31, 2016 12:48 PM
konstantinosIX
Mar 13, 2008 06:25 AM
steexz
Aug 12, 2007 12:56 PM
