FIC Bluemax Injectors + EMS
Is anyone using these injectors?? I wanted to get some feed back on the injectors and see if anyone has any. I'm looking to buy 1650cc.. Any input would be welcome.
-Drivability
-02 feed back? (Can it control it?)
-Gas mileage changed??
I'm not interested in any other injectors. Only feedback on the FIC Bluemax PLEASE
Thanks in advance
-Drivability
Thanks in advance
-Drivability
Thanks in advance
-Drivability
Thanks in advance
Please tell me that they are ball and seat style injectors? I have heard roomers that they were developing some but I haven't ever seen them released. You might need to send them into AEM to have them tested unless FIC can confirm their battery offset.
The new blue max injectors comes with a stat sheet with the battery latancy. They are in MS rather then Usec like the AEM uses for the battery offset table. If anyone knows how to convert MS to Usec it would help greatly. I have a customer over here that just got 1450cc blue max injectors. Still haven't been able to figure out how to convert MS to Usec to key in the battery offset.
Currently I'm just using the ford motorsport 1600cc battery offset table, they seem to work "ok" but I'm sure they can perform better with the correct battery offset. But I can say they are 10x's easier to tune then the blue top 1600cc injectors. They have a wider range then the blue tops do it seems. With the blue tops it seems that you just barely make an adjustment on the fueling and the A/F ratio will change drastically. The blue max 1450's tune almost like 1250's.
^ gtvevo said to take their value of lets say 1.850 for 11v, input the number 1850 for the same voltage within the battery offset table.
the aem electronic tech line confirmed this method as well.
Really? Very interesting, that makes life allot easier. Thanks for sharing!
Then are ball and seat style. Nothing like the ford 1600cc. much better spray pattern..
socalx_dsm
11
Jul 21, 2016 11:51 AM
bigturboevo80
Nov 11, 2010 10:13 PM
