AEM EMS Get tuning help for your AEM EMS system.
need map help and help with injectors!! evo ix with 30-1320 ems
Old Dec 25, 2009 | 11:24 AM
droppedrx7's Avatar
picking out injectors. somewhere in the aem injection basics book i read not to use low impedence/peak and hold injectors with the pems, it also said that with the pnp pems?? i can use that style injectors, but with aem ems i have to use the saturated type?? or if i use peak and hold style i need to use resistors???
wtf im clueless haha can someone just tell me what kind of injectors to use or what i have to do? i have an 06 evo ix with the aem 30-1320 ems and all i wanna do is buy some injectors! please help.
im also looking for a base map or one with some mild upgrade tuning already done to it so i can tune from there. i saw a sticker on my ems that said do not attempt to start until a base map has been loaded, so i need something to get me started. i have a cosworth 2.0 with kelford 272s and a gt42r, manifolds, throttle body, cop ignition, stand alone fuel system with cell, pump, regulator and etc.etc.etc, still using mivec. if theres a map somewhere around there that i can get started with that would be great, even a stock/base one would help me get started! also what size injectors for the above setup do you reccomend, would 1000 cc injectors handle that or bigger?
so: i need some sort of a map to uplad to get me running atleast, i need to know what kind of injectors to run and what size injectors to run.
ive posted on the aem forum and still have gotten no replies. so please help..i just wanna drive my car that has sat in the garage with no motor being build for a year and a half haha thank you all!
Old Dec 25, 2009 | 11:25 AM
droppedrx7's Avatar
also with the 30-1320 its not the uego compatible one, i dont think. so how can i wire in a zeitronix wide band 02 sensor, i would like to do some tuning by the afr and if i cant wire in my zeitronix wideband to it how will i do this? thank you all so much!!
NewEvolutionIX
Apr 20, 2015 05:25 PM
EVO_RYAN
20
Jun 16, 2010 07:59 PM
2JZfan
10
Aug 20, 2009 11:38 AM
loppad
AEM EMS
Oct 7, 2008 12:18 PM
