changing stock coils for ls2
will use pin 16 & 52,on coil output turn on 3 & 4,but how i select firing order? i guess have something with igntion tooth. any tips?
Be carefull. I know the delphi truck coils will not work with the evo8 ems. I tried that myself. I know the LS1 coils work for sure. Also, you dont have to make them sequential. You can wire them in batch ( 1/4 2/3 ) like the spoolin-up c.o.p. does. But if you want them sequential do this...
1- wire the coils in order. ie: coil 1 output to coil 1, 2 to 2, ect.....
2- turn on your 3/4 coil outputs under options/coil.
3- go to ignition/ignition advanced/ phasing. from there name the 1,2,3,4 outputs in firing order. ie: 1=1 2=4 3=2 4=3
if your not sure you have it right i believe there is a base map for an evo9 with 4 coils. compare your settings with them as they should be the same.
uuummm,i can get a bargain for those coils with conectors,was thinking to use it waste spark since my 3g eclipse with 30-1313 doesnt have the pin 16 and 52 wired and have to mess with this. i have used ls2 and ls1 on haltech only need to play with dwell time.now you make me wonder if get the coils or not.
need help
i am using a set of honda coils, i tried using the evo9 settings and the car didnt start. i used the evo 8 set up and the car started but missed on cylinder 4, although the coils and injector were both firing. any help will be apreciated, thanks. by the way, when i go back waste spark everything works.
FS[Northeast]: Carbon Fiber Coil Pack Cover & Evo 9 Coil Packs
Rossi_24
May 21, 2016 09:09 AM
WTB[MidWest]: Coil cover
murderedout
Feb 26, 2016 02:59 AM
dillons13
Jul 19, 2015 10:48 PM
