AEM EMS Get tuning help for your AEM EMS system.
For those using GT35R Turbos
Old Sep 27, 2011 | 11:59 AM
Blue91lx's Avatar
Personally, I'm not worried too much about the lag. I don't like the idea of having to spin my motor out to 8k every time to utilize my powerband.
Old Sep 30, 2011 | 05:50 PM
fre's Avatar
fre
Been revving my stock engine with 272 HKS cams the last 4 years to 8500-8600rpm and haven't had any issues. I put Brian Crower springs in my head about a a year and a half ago to give me a little more insurance, but no issues yet. Engine has 100k on it now. I would say 30psi full boost shouldn't be expected much before 4900 rpm and for my non HTA model it is more like 5300rpm. This is assuming no head/engine mods to help spool. That was on my .63 turbine housing which I found to have some cracks in it. Just switched to a .82, so it will be interesting to see the results.
Old Oct 4, 2011 | 07:32 PM
Blue91lx's Avatar
That will be interesting to see results fre. I am getting my car tuned next week. It's a non-HTA GT35r with a .63 housing and a Shearer Manifold. I have Brian Crower Springs/Retainers, GSC S2 cams, Wiseco 10:1 pistons, Eagle Rods, a Nisei Intercooler, custom piping, and a custom dump. I have one Warlboro in the tank and one before the rail and 1000cc Injectors. We shall see how it goes. I sure hope I can spool a little before 5k, or I'm going to rip it off and throw a FP setup on there for quicker spool. What spool difference are you guys noticing between HTA and Non-HTA 35r's?
Old Oct 4, 2011 | 08:02 PM
detroit pistins's Avatar
I am currently running an hta3586r + .63 and planning on upgrading the hotside to a .82 (if I dont sell her!), so I took some data and hoping to compare it to the .82 down the rd. hope this helps!
engine setup: turbo kit, GSC S2's, 3.5'' ic with 2.5'' ic piping and everything else is stock (tb, int manni, block, head ports....etc).
cheers!
Old Oct 5, 2011 | 05:47 PM
fre's Avatar
fre
That looks about right 5k for 26psi maybe slightly higher for 30psi. Unfortunately, I won't be upgrading to the fp 3586 variant until I build my engine. I figure the 400wtq I am throwing at the stock block is plenty. Will get a more exact figure from my logs when I get back. I did have a crack in my hotside though, so that could have definitely effected my spool.
Old Oct 31, 2011 | 06:31 PM
yasser's Avatar
i have gt35r
in about 3700 rpm
Old Dec 20, 2011 | 09:14 PM
fre's Avatar
fre
results for .82 is 20psi by 5300 and 32psi by 5700. My .63 did about 2-300 rpm better 5450 was 31.5 psi, but I gained about 15whp with the .82
Old Dec 21, 2011 | 09:04 PM
good results. what gear was that in? 3rd gear I assume?
I swaped to the 82 hotside, and got a bunch of data, processing them at the moment and will share. Generaly speaking tho, looks like I lost around 150-250 rpm worth of spool...surprisingly!
cheers!
Old Dec 22, 2011 | 12:31 PM
fre's Avatar
fre
Yea it was 3rd gear and the spool loss seems to be the same with you, so no surprise there. I noticed about the same amount of pickup in torque as well (+15wtq).
Mevo8M
14
Dec 2, 2012 12:29 AM
bertune
10
May 22, 2009 10:42 AM
evoboy83
96
Aug 1, 2008 10:38 PM
blackonblackevo
26
May 28, 2007 09:31 AM
blackonblackevo
Mar 27, 2007 09:14 PM
