AEM EMS Get tuning help for your AEM EMS system.
For those using GT35R Turbos
Old Jan 16, 2004 | 11:24 AM
Crazy4Cars's Avatar
I need to know, at what rpm does the GT35R starts spooling, I currently have the GT30R and I'm thinking on upgrading to the 35R, also what back housing are you using it, I have the 0.87.
Old Jan 16, 2004 | 11:28 AM
evo_08's Avatar
no te gusta el gredy t67?
Old Jan 26, 2004 | 07:39 PM
evo542's Avatar
i think it is anywhere from 3500rpms to 4000rpms(full boost)
Old Jan 27, 2004 | 12:10 AM
superz's Avatar
absolutely not, expect full boost no sooner than 4400rpm's at best.
Old Feb 1, 2004 | 10:34 PM
Wadzii's Avatar
the GT turbos are VERY efficent. you should have full boost by 4500rpms. we run precision sc61's and those DONT have a gt wheel on the turbine side, but are capable of similar hp. the sc61 normally spools by 4800rpms. the gt35r should spool up faster than the sc61.
Old Feb 17, 2004 | 10:19 PM
QuantumEVO's Avatar
Ditto; for 1 bar.
Old Sep 17, 2011 | 11:56 AM
mlancerevo8's Avatar
i have full boost on a .63 at 3500-4000 wot at 30psi...
Old Sep 17, 2011 | 12:28 PM
1UpMoto's Avatar
Its been soo long since I had my 35r, but I know for a fact it spooled alot quicker than my 6262. The lag on a 35r isnt too bad at all. Ive had a 50 trim, 3076, 35r, 6262, and I think the 35r was the funnest to drive.
Old Sep 17, 2011 | 01:07 PM
uvambo's Avatar
Yea unless you do many special things to the car and mods to help spool there is no way you can expect 3500 spool out of a 35r. Even most stroked 35r set ups are spooling after 4000. So expect at least 4400 plus for full boost, on a 2.0.
I have a 2.0 with .63 hotside.
"Spooling" at 4300 =20psi
and hitting full boost at 4800 to 5000
Old Sep 17, 2011 | 01:29 PM
lude2evo's Avatar
way to bump a 7 year old thread
Old Sep 17, 2011 | 01:50 PM
lonestarevo83's Avatar
So on a 2.3 what could you expect? 3800 or so?
gt3582R
Old Sep 18, 2011 | 07:40 PM
mrboost05's Avatar
gt3582R
expect it 3-400rpm earlier then a 2.0 but its not going to hit 20+psi at 3800
Old Sep 25, 2011 | 12:14 PM
myns a 2.0 with 280 cams ported and polished and i see 20-25lbs between 3500-4 n 30lbs right after 4...
Old Sep 25, 2011 | 12:57 PM
Blue91lx's Avatar
The car in my Sig is getting tuned with S2's and a Nisei so I will update this with what I find as well.
Old Sep 27, 2011 | 11:52 AM
THANGEVO's Avatar
Unless you autocross the car you I wouldn't worry about turbo lags I have the hta 3586 on 2.3 and it come on instantly and get 22psi at like 4300 rpm at 4900 rpm I got 525 torque to the wheels on the dyno
