AEM EMS Get tuning help for your AEM EMS system.
AEM Series 2 Evo 9 Mivec not responding
Old Feb 12, 2018, 04:23 PM
Sandroc's Avatar
So I got my car back together after a new built motor. My tuner went to start tuning and noticed the car wasn’t acting right. As he was checking everything he noticed that my mivec was showing advanced to 39.96. No matter what target value he put in it wouldn’t change. Has anyone else have this happen?
Setup on car is
Built 2.0l block
Built head with kelford 280/276 cams
FP Black
Old Feb 16, 2018, 12:21 PM
2006EvoIXer's Avatar
Did you check if your intake cam sensor is connected?
Old Feb 16, 2018, 02:25 PM
Sandroc's Avatar
I have. I have noticed that on the 9 the cam sensors have different part numbers. What happens if you put the wrong one in?
Old Feb 16, 2018, 03:29 PM
By putting exhaust sensor in the back and the intake sensor in the front? Both sensors are the same part.
Old Feb 16, 2018, 03:42 PM
Sandroc's Avatar
Yeah. I thought I saw some where they had different part numbers on the evo 9.
Old Feb 16, 2018, 03:45 PM
I think the Evo 9s have both sensor and Evo 8s only have the exhaust cam sensor. From a quick search, sensors are all the same.
Old Feb 16, 2018, 03:48 PM
If both sensors are the same, try switching them and see if it runs differently.
Old Mar 8, 2018, 04:02 PM
Sandroc's Avatar
Just for the record on the evo 9 if you do not have the correct cam position sensor in place then the mivec will not work. I ordered new oem sensors and installed them and the mivec started working.
2006EvoIXer (Mar 8, 2018)
Old Mar 8, 2018, 05:30 PM
So intake cam sensor is different from exhaust cam sensor? I check on an online store before and it showed the same part number.
Old Mar 12, 2018, 10:02 AM
Sandroc's Avatar
Sorry for the delay. The part numbers are different.
Exh md327107
Intake mr507814
2006EvoIXer (Mar 13, 2018)
Johnboy1065
Jul 22, 2012 11:16 PM
Zoxygen
Apr 13, 2007 07:04 PM
Quick Reply: AEM Series 2 Evo 9 Mivec not responding
