logging paremeter's
i have made a few logs on the laptop and tried to change the paremeter's of the log. i currently cannot view knock figures at all on the current log. i went to graph setup and scrolled thru the paremeter options and knock is not an option anywhere. what and how do i get it into one of the options for the log. Any help will be greatly appreciated :mitsu:
What is logged is dependent on what Parameters window you have displayed in AEM Pro while logging via the laptop. If your viewing the Egine Start parameters screen and logging in AEM Pro, then those are the only parameters you can choose from in the AEM LOG drop down box. |
what he said.
just open a paramaters window.. unlock it.. add in what you want to log.. and save it as a template. then when you want to log stuff, just click the template button and hit f6. |
ok so how do i change the window and what is being displayed
close all the windows. view -> parameters. add fields you want lock templates - > save. add the button. done. |
ok cool appreciate it . can i set this up offline
The icons that run along the top of the screen are shortcuts to various windows of the AEM software along with the parameters for those tuning options, IE Engine Start, Fuel, Ignition, Tuning, etc. These are the default parameters that AEM has suggested are best to be viewed while tuning this area of the AEM software. You can choose like Ryan said to unlock the parameters window and add/subtract parameters to view.
yup. |
Yes you can set it up offline.
just hooked it up fellas thanks a million
as long as that paremeter window is up and viewing data that is what will get logged correct??
yup |
| All times are GMT -7. The time now is 11:18 PM. |
