-   AEM EMS (https://www.evolutionm.net/forums/aem-ems-99/)
-   -   What's your 2-step at, and how much boost do you build?? (https://www.evolutionm.net/forums/aem-ems/426481-whats-your-2-step-how-much-boost-do-you-build.html)
Tbtalon94 Jun 10, 2009 12:58 PM
Thought I'd get something kind of rolling here on what people are seeing.
List your motor size, cams, turbo, and 2-step RPM along with what cut (1 soft- 10hard) and finally how much boost you build...
motor = 2.0L
cams = HKS 272's
turbo = 20g_9lt
RPM = 5,000rpms
Cut = 1 (soft)
Boost = 3-4psi
I moved the cut to 5, but haven't tried it so I'm interested in what others see. A local with a built 2.0L and 42r with a ~6k 2-step on 5-cut only built a couple psi.
kanyonkid Jun 10, 2009 01:00 PM
motor=stock
cams=kelford 272's
turbo=stock
rpm=6k
cut=????dont know what that means
boost=0.6 bars
timing for 2 step is 10, fuel is 10.0
before we did that "2step tune" it still read 0.6bar boost but now my WG opens while 2steppin but still reads the same boost
veta Jun 11, 2009 11:30 AM
2L
FPGreen
Retard on 4500RPM
IGN Cut at 6500RPM
building 25PSI at cca 6000RPM
evoracingstar Jun 11, 2009 11:33 AM
stock motor
cosworth 272
hta 35r
two step 7000rpm
big block ix Jun 11, 2009 11:36 AM
5500
k2boarder3187 Jun 28, 2009 03:25 PM
6000
15psi
project_skyline Jul 9, 2009 11:09 PM
When i had the aem on my car with the stock 9 turbo with the following settings i could build 20-22 psi.
fuel cut 5700
ig cut 5600
retard rev 5610
fuel cut level 2
Evostacio Jul 9, 2009 11:25 PM
mines at 5500 i think it builds like 5 to 10 let me double check its been a while since ive launched it
evoix16 Jul 9, 2009 11:30 PM
2.3 stroker
ams 850r kit
gsc s2
ams fmic with licp and uicp
exedy twin
and all supporting mods
6200 rpm with 12 - 14 psi stock ecu
browningderek Jul 11, 2009 12:57 PM
2.3
hta86
aem ems
comp 272 cams
buschur front mount
stock intake & head
6000rpm fuel cut
12000rpm ign cut
6000 rev retard
-17 ign under 2 step w/ no fuel added
12psi and blows all 4 tires off
QM twin dics
neonglh Aug 22, 2009 05:19 PM
I build 9 psi with my AEM 2 step set to 6k rpm. This is on a 9 turbo. With anti-lag we were building up 18 psi, but it was fowling plugs, so we stuck with the safe method.
raiceboi697 Sep 7, 2009 06:53 AM
motor = stock
cams = cosworth m2
turbo = 35r
RPM = 6200
Boost = 21 psi
man i love antilag
Pure Playaer Sep 7, 2009 07:06 AM
Mods in my sig, AEM EMS.
RPM = 6,000
Boost = 6PSI
.. For some reason I think 6psi on a 6262 @ 2-Step Is a little low, does anyone agree?
raiceboi697 Sep 7, 2009 12:53 PM
^^ from what ive seen of those i would think your would want more to get you off the line quick fast & in a hurry. try drag style anti lag im sure you will love it!
travail Sep 21, 2009 10:59 AM
motor = 2.3L stroker
cams = HKS 280's
turbo = GT35R
RPM = 6,200rpms
Boost = 11psi
