DOHC for 4g94 engine
Something I would like to do to my car before I install a turbo is replace the SOHC head with a DOHC head. Anyone done this or know of a way to do this?
:dunno: |
i dunno... i am searching myself... good luck
Anything is Possible
Hey monkiboy, i already asked if i could use the Dohc head off of the 2.0 Evo and everybody told me it couldnt be done. I have this friend that blew his Sohc head on his neon and nobody said the Dohc on the other neon, probably rt, would fit and he said it went right on with ease. I think nobody would know unless they actually try it. First thing i would do is look at the dimensions of the block and head and do some comparing. I think those japanese guys are always two steps ahead of everybody else. Theres bound to be a head out there for a substitute. If you do find one though let me know, or im just going to port mine out secretly. Thanks, Dusty.
The work and cost involved in this conversion out weigh the benifits. You could use a 4G93 DOHC head off a 97+ engine and then start playing around. The 4G63 DOHC head will not fit onto the 4G94 SOHC block. If you have a closer look the 4G94 SOHC uses the almost the same head as the 4G93 SOHC. I hope that has helped :)
as well as making sure that all of the water cooling holes ect on the inside of the motor match up as well other wise you could be in for some very expensive repairing
ill be doing this conversion myself soon. 4g94 short block with forged rods and pistons with 4g93 dohc heads. Ill be uploading any info etc. As well as the build when i get to it.
Originally Posted by CE_GSR1.8
(Post 9652862)
