2015 SE AWC AFR issues
Hey guys,
Not sure how active this forum is lately.
I've been having issues with my AFR after installing a ram air intake.
When I'm sitting idle my AFR is sitting at 16:1 when everything I read it's normal idle is 14.7:1. I have check every inch of vacuum hose and any other leak points and there is nothing leaking. When I'm moving and cruising the AFR will drop to 14.2-14.8 during acceleration and once I'm cruising at about 50mph it raises to about 15.2-15.5 and sits there until I slow or punch the gas.
Others suggested check the breather as excess air can get in there but it's all metered after the MAF and sealed tight.
I will take any help or suggestions you guys can think of.
