Breaking up at high rpms
Old Mar 29, 2012 | 03:18 PM
Mag00n's Avatar
Hi all,
I just installed a downpipe-back exhaust and Ive been trying a few maps but all of them I have been breaking up/stuttering at like 5500+. Mods are k&n drop in, perrin upper pipe and the 3" dp back. Before the exhaust i was running either the stage1 93 v200 or stage 1 93 hks with good results
I have tried stage 2 93 v200 and stage2 93 hks. If Im worried about running lean is reasonable to assume the 91 tune would run a bit rich with 93oct?
I will try to get some logs up, i havent logged with the ap yet.
Old Mar 29, 2012 | 03:38 PM
just1n020's Avatar
Or you can run the LWG map. Plus is the boost pill still in? But you really need to log to see whats going on. But do you have a boost gauge installed? If so were you seeing any spikes above 25psi. Plus did you add a test pipe or high flow cat. Just curious. And running a 91 map should richen you up a bit. Maybe you got some bad gas in the car now.
Old Mar 29, 2012 | 03:42 PM
Mag00n's Avatar
boost pill is still in. I have a defi boost gauge. Its not reading too high above 25, maybe 26ish in 4th gear. Its a test pipe.
Im reading up on what to log now.
Old Apr 2, 2012 | 11:43 AM
Kracka's Avatar
Check your fuel pump relay and FPR vacuum line.
Old Apr 2, 2012 | 09:05 PM
AWDXTCY's Avatar
I had the exact same issue except I ran the stage 2 and was breaking up around 5500 rpm's and it turned out to be the fuel pump relay...
Old Apr 3, 2012 | 02:23 PM
Mag00n's Avatar
It was the fuel pump relay . THANK YOU. Car is running very well now.
Old Apr 18, 2012 | 02:58 PM
Dreamer666's Avatar
Hi.
Have already checked my relay but where is the vacuum line and what do I need to do to fix/check it?
Tnx in advance!
ChipperEvo
Cobb AccessPORT
Dec 2, 2012 07:33 PM
yoshe200
Cobb AccessPORT
29
Apr 5, 2012 06:55 PM
EvoXRed
Jul 5, 2011 07:34 AM
GetterDragun
Oct 18, 2010 01:31 PM
weebles
23
Aug 13, 2009 08:50 PM
