2011 MR AP mod questions
So I want to get the cobb ap. Wanting to buy an exhaust this week, I have a K&N typhoon intake and uicp installed. Just wondering what map I should run after I buy the exhaust? Thinking catback with test pipe. Thoughts? Thanks alot in advance for the help.
install stage 2 with stock intake do some logging send the logs to BakaUnchi and he can help you fine tune the map for your car.
catback + intake is stage 2. do some logging and send your logs in. jon might help you adjust your maps to your car.
Oh ok. Yea I read install my stock intake and run stage 2 maps. Ill run stage 1 until my exhaust comes in. Then stage 2 and send the maps in. I will be buying parts for turboback, after I get those will Ijust send in some more logs to have them fine tune it the rest of the way? Thanks for the help.
This is def not true.. There is a regular, non intake, stage 2 map
Cobb has said CBE is enough for stage 2 map and there are folks who flash stage 2 bone stock because they don't like the stage 1.
Stage 2 basically is adapted to higher exhaust flow so I would think worst case using it with more restrictive exhaust is less power.
The other way would be more dangerous - giving too much air to a tune that cant compensate and disabling the safety net code for too much air.
This one also isn't right.. Cobbs "test pipe" is a high flow cat (I have it), so technically a "proper" Cobb stage 2 (all cobb parts) is still catted
From what i've read, you do not run stage 2 with stock cat, period
