map advice 2011 GSR
Old Apr 3, 2014 | 11:27 AM
cla2000's Avatar
map advice 2011 GSR
Hello. I have a 2011 GSR. I just purchased an ETS quiet exhaust, COBB high flow cat and a COBB short air intake. What map should i use for the mods I am about to install? I use 93 octane fuel. Thank you and I hope this is the right place to post this.
Old Apr 3, 2014 | 01:09 PM
stryderlis's Avatar
I would use the stage 2 map with the intake update. You can modify the stage 2 map to work with the cobb intake. There's a video showing you how to update the map on cobbs site.
Old Apr 3, 2014 | 01:40 PM
COBB Tuning's Avatar
I would run stage 1 93 map until you get a downpipe. You can find the guide to scaling your intake with ATR here.
https://cobbtuning.zendesk.com/hc/en...on-Spreadsheet
-Chris
Old Apr 3, 2014 | 05:25 PM
cla2000's Avatar
Ok... I was ready to run stage 3. I didn't think a downpipe mattered all that much on evo X
Old Apr 5, 2014 | 04:09 PM
Sj119808's Avatar
highly recommend the ets downpipe. aaaand stage 2 with that.
Old Apr 6, 2014 | 12:28 PM
Without a downpipe there can be excessive heat build up that can cause detonation, we do not recommend running a stage 2 map until you have a full turbo back. A stage 3 tune will need a 3 port boost control solenoid, it is not compatible with stock boost control solenoids.
-Chris
Old Apr 6, 2014 | 08:23 PM
stryderlis's Avatar
-Chris
Are we talking about just the piece below or from the o2 back? I was under the impression that just the piece below doesn't yield any gains but would like to know Cobbs take on it.
http://www.cobbtuning.com/Mitsubishi...e-p/552200.htm
Old Apr 7, 2014 | 06:57 AM
Yes or any of the other downpipes on the market will increase flow and aid in heat transfer.
Old Apr 7, 2014 | 07:04 PM
cla2000's Avatar
Ok. I installed my cobb high flow cat, ets cat back and cobb sf inrake. I used different maps, including a stage 3. Car seems slower in all maps I tried, and it is ridiculously loud, to the point that I hate driving it now. After loading different maps, with each one I tried, I get a service engine soon light.
It comes on after driving around for a few miles, usually more than 10 I think.
Right now I am using a stage 1 map, ver. 403 that I changed the values in for the new air filter, using access tuner. I did follow the directions on cobbs site. The car runs a little better, still very loud, but pulls harder when I step on if. Unfortunately I still got the engine light on, code p0420. Max boost was about 25 psi, only one time. Normally doesn't go over 22 psi. I had 2 counts of knock the most. Temp outside is 46 degrees.
Old Apr 9, 2014 | 10:53 AM
stryderlis's Avatar
Usually when you change your exhaust it gets louder, if you don't want loud you need to stick with the stock exhaust. Which ETS exhaust did you install?
Saudi
Cobb AccessPORT
Dec 13, 2019 04:05 AM
Eurus
Cobb AccessPORT
Jul 20, 2015 12:44 PM
baffula
Cobb AccessPORT
Feb 6, 2012 05:03 PM
Fooj Evo x
Cobb AccessPORT
Nov 26, 2011 11:58 AM
JG
Cobb AccessPORT
Nov 18, 2011 04:18 PM
