Is this typical behavior for the stage 1 tune?
my mods are:
k&n drop in nisie 1pc upper I just installed the cobb ap and used the hks panel stage 1 map whats happening is when i do a pull from say 3rd gear, it will spool to ~25psi, drop to like 16psi at 5kish, the pick back up to ~20 then taper to 17ish by redline i know target peak is around 25 with taper to 17 by redline but im not sure about the dip at 5k, you can definitely feel it, feels like a slight hesitation then it starts going again. Sorry if this is the wrong place or a dumb question, im a little new to the AP |
Originally Posted by Mag00n
(Post 9665458)
my mods are:
k&n drop in nisie 1pc upper I just installed the cobb ap and used the hks panel stage 1 map whats happening is when i do a pull from say 3rd gear, it will spool to ~25psi, drop to like 16psi at 5kish, the pick back up to ~20 then taper to 17ish by redline i know target peak is around 25 with taper to 17 by redline but im not sure about the dip at 5k, you can definitely feel it, feels like a slight hesitation then it starts going again. Sorry if this is the wrong place or a dumb question, im a little new to the AP AKA LWG |
