Launching with an auto ralliart.
Dont laugh! Im not a car racing kind of guy but im just wondering how you would launch properly with an auto ralliart.
I reved it up in neutral and then just slid it into drive witch actually worked very well. The tires spin quite a bit. I never tried this before. I used to just simply hit the gas in drive which sucks compared to starting in neutral. Im wondering if this is the right way to do it with an auto ralliart, or is there a better way?
Thanks!
Thanks!
ouch, your hurting yourcar by nuetral dropping it. it's much better on the car(although still bad) to hold the brake and gas at same time then release the brake when you get to the prefered rpm...
edit: all while in the "D" gear on your auto
Im just wondering how autos would race off the start properly.
Originally Posted by RaLLi
Haha. Thanks. I only tried it once just to see and im not planning on doing it again. How do you know it hurts the car though? It says in the manual you can slide it from neutral to drive without pressing the button.
you can see it on the Grand nationals.
hope this help ..
Originally Posted by GarageRM
the way you launch an autos.. is put in drive step on the gas and floor it.. (don't be afraid.).. you rpm will rised to a certain RPM.. and that Rpm is your stall Rpm ( depending on the car prob above 2k). now when you feelt ready to launch the car.. just release the break and let it rip.. side note on a turbo car this's how you build boost, and enable autos to launch at higher boost than a manual, depending on the car stall Rpm.
hope this help ..
hope this help ..
Ralliartize It
Apr 28, 2013 03:46 PM
