Why the 6spd sucks at altitude! (vid)
Old Apr 24, 2006 | 06:14 AM
  #106
FathouseFab's Avatar
Originally Posted by housedj
as far as the 7 bar map sensor goes, Warr's feathers get ruffled easy when i post so even if i have accurate info he won't believe it. ask him about my thoughts on humidity...
Your thoughts on humidity is one of the stupidest things I have ever heard.
Fathouse
Old Apr 24, 2006 | 06:49 AM
  #107
TTP Engineering's Avatar
Originally Posted by supertuner housedj
Ask me about my wastegate mod!!!!
adjust the w/g turnbuckle all the way down to hold boost. cheaper than spending $150 on a Forge.
This is the big hype? It's no wonder all these people are having boost creep issues...
Old Apr 24, 2006 | 01:38 PM
  #108
Karash's Avatar
If you are still using a MBC you might think about going up to a good EBC.
The AVC-R for instance will allow you to set per gear sol duty adjustments allowing you to correct for a lot of enviromental or load concerns.
Old Apr 24, 2006 | 02:13 PM
  #109
matt55's Avatar
my point has been made earlier in the thread. you need more air to make power. what would work best for you at this point are the following items:
Intake manifold (HKS Kansai w/90mm TB) since the air is thin there
Cam gears (try either -3,-3 or better yet -4, -1) to get the torque back u lost
Ditch those cams (need more lift/duration on exhaust side) since turbo is out of breath
5 or 7 bar map sensor so you can spike turbo higher
Ignition amp of some kind since stock igniton begins misfiring over 27psi
i ASSURE you these items will help in that elevation. if all the above items have been tried & they still don't work, then your only other option is to increase CFM by going big turbo. but u knew that already...
We got to stop this maddness
dude , for real , drugs are bad .
Old Apr 24, 2006 | 06:10 PM
  #110
TrinaBabe's Avatar
the only way to get cams to work without cam gears is with a standalone unit. also your 264exhaust cam is why your car is falling on its face up top. cam gears don't just move the powerband, they WIDEN it also. if a 2nd gen DSM can make 46whp with 272 cams, what's your excuse??
Did you get banned already? I thought there was a petition or something to get you to shut up.
Old Apr 25, 2006 | 12:06 AM
  #111
housedj's Avatar
and why would anyone want to do that? if you're annoyed by what i say don't read it/respond to it. no one takes advice on forums anyway. it is merely part entertainment, part experience sharing, part comedy, and most of all part fun. i offered Warr some things he might be able to use, & i threw in some things to get him riled up. there is no harm in that. he will do what his knowledge, experience & sponsors tell him to do to overcome his situation. iirc, 1/2 the members on the evoM don't like him either. i don't hate the guy. he will get his car dialed in & we will read about it. some will bash some will cheer, you may not agree but i'm still here...
Old Apr 25, 2006 | 12:26 AM
  #112
EvoRecordSetter's Avatar
cool video try your set up at sea level!!
Old Apr 25, 2006 | 05:01 AM
  #113
matt55's Avatar
. no one takes advice on forums anyway. it is merely part entertainment, part experience sharing, part comedy, and most of all part fun. ...
Hmmm i do take advice from this site , and i dont think Evom is a joke .
You are start to resemble " K- fed " with all these douchebag commits .
Old Apr 25, 2006 | 07:53 AM
  #114
Warrtalon's Avatar
Yeah, tons of people take advice from here...in fact, I think MOST people who come to EvoM follow at least some form of advice at least once while here while many follow what is said to a tee, because they don't have a lot of experience. The sheer number of PMs that I get asking for advice tells me this is true.
If you are now trying to say that your responses were half-jokes, then you should be silenced, but I really think you believe this stuff and are backpedaling after everyone calls you out...kinda like the other times you stepped in it.
EvoRecordSetter, the closest track that is less than 2000' of elevation is 350 miles east in Kansas - I think it's 1350' - but that's a long trip to go drag racing just to see some ETs. I'd hate to break something 350 miles from home, but it sure is tempting. I know where the track is only because I've already thought about it, heh...
Old Apr 25, 2006 | 08:12 AM
  #115
GTKage's Avatar
housedj do us a favor and stop posting on this forum, everything i read from u on this forum has been idiotic crap, so please stop. once u go to the tack and set some kind of "record" we dont want to hear anything about u, ur car or ur stupid mods.
Warr, that sucks that ur ET decreased that much, i think it s time for some Nitrous
Old Apr 25, 2006 | 02:08 PM
  #116
dsmfan95's Avatar
I make decisions based on a lot of things I see on this forum.
Old Apr 25, 2006 | 03:50 PM
  #117
EvoTio's Avatar
I tend to take the things I read on Evom with a grain of salt. After you've been on here a while you get to learn who knows what they're taking about and who is full of crap. I feel sorry for the newbies who really want to learn and then get steered in the wrong direction.
Old Apr 25, 2006 | 07:01 PM
  #118
jrsimon27's Avatar
warr how many tenths do you think you can shave off the 1/4 mile at sea level?? do you think this is your problem that your 3500'?
Old Apr 25, 2006 | 07:06 PM
  #119
jrsimon27's Avatar
3500 feet?
Old Apr 25, 2006 | 07:07 PM
  #120
jrsimon27's Avatar
sorry i meant 6000 feet?
