Taller tire to change gear?
Anyone running a taller tire at the drag strip? Im out of gear. 131 at 8500rpm. I was thinking a 235/50/17 or 245/50/17 would give me 4-7 more mph at the same rpm. Curious if these sizes would fit witout any problems. Car isnt lowered. I dont wanna shift to 5th as it seems to not give any change in time or speed and I messed up the 5th gear syncro once already doing that.
Anyone doing this?
Anyone doing this?
You should be a touch faster at 8,500... more like 135ish... perhaps they are worn tires though.
And yes you could run a taller tire but it will most likely hurt the ET some but raise the MPH slightly. You are better off running another 100-200 rpms. At 8750 you should be about 140.
And if you are trapping at 140+ your motor will probably start getting upset at the power your making so you build it and rev it to 10k... That will solve your problem perfectly.
