Going back today to the track
Old May 17, 2006 | 12:31 PM
EVIL_EVO_VIII's Avatar
Well im going back to the track today to run a better time. My best was 12.7@108.96 with a crappy 1.8 60ft... Any advice you guys can give? Tips? I wana try to hit 110 in the 1/4.... Its kinda hot today so we'll see what happens!
Old May 17, 2006 | 12:35 PM
tke_413's Avatar
Let it go man, fix it later!
Old May 17, 2006 | 12:38 PM
freshevo8's Avatar
lower the tire pressure to 22psi, launch around 6k(quickslip), and try WOT shifting(hold the gas pedal down, hit the clutch quick) from 3rd to 4th.
WOT- wide open throttle
GOOD LUCK
Old May 17, 2006 | 12:40 PM
huh? what r u talking about?
Old May 17, 2006 | 12:43 PM
freshevo8's Avatar
btw, your prolly not goin to hit 110mph with the tire pressure lowered to 22psi, but if everything goes smooth with what i wrote up above, you'll see a better time...........guaranteed!
Old May 17, 2006 | 12:46 PM
Thanks bud
Old May 17, 2006 | 12:54 PM
Rnm's Avatar
Rnm
Good luck.
Old May 17, 2006 | 12:57 PM
KOEvo's Avatar
If you want 110 run stock tire pressure and shift lower.
Old May 17, 2006 | 01:11 PM
shift lower?
Old May 17, 2006 | 01:19 PM
freshevo8's Avatar
Originally Posted by EVIL_EVO_VIII
shift lower?
thats something i forgot to tell you. u should be shifting right at 7k, some say 6800-6900rpm, but not over 7k because that should be close to your peak power. anything over you start to lose power with your mods and stock turbo/motor.
Old May 17, 2006 | 01:23 PM
Ok will do, i was shifting at 7800 last time
Old May 17, 2006 | 01:50 PM
jqturbo's Avatar
Let it go, fix it later means just the hell with all, and let 'er rip! Don't have any worries about tranny, clutch, power shifting, etc. Just go all out on the run without a care in the world! And hopefully you will get a great time and nothing will break!...but if it does, fix it later!
At least that's what it means to me! Good luck Miguel. I wanted to go watch but I got dinner plans instead.
Old May 17, 2006 | 01:57 PM
tke_413's Avatar
If I could explain it....that's exactly how I would word it. It'll always be in the back of your mind...but if you just go out and run it hard and have fun, you should see some good runs. Hopefully nothing breaks, but then again why go race if you're scared of breaking something.
Old May 17, 2006 | 02:03 PM
matt55's Avatar
7.8k , no cams shifting
Old May 17, 2006 | 02:39 PM
freshevo8's Avatar
damn killer! u should definately see some better times today! also, what boost/octane are u running at and what bov?
